IOS XRv 9k 7.4.2 not booting in eve-ng
IG
Hi All,
I am trying to boot up an IOS XRv 9k 7.4.2 in eve-ng but its not booting, it rebooted in the first 2-3 minutes and afterwards its doing nothing, i can see the following message on the console but its not progressing any further. any idea please ?
IG
# Welcome to the Cisco IOS XRv9k platform #
# Please wait for Cisco IOS XR to start. #
# Copyright (c) 2014-2019, 2021 by Cisco Systems, Inc. #
Cisco IOS XR console will start on the 1st serial port
Cisco IOS XR aux console will start on the 2nd serial port
Cisco Calvados console will start on the 3rd serial port
5 Replies 5
JKOOP
I would wait. This image will take a long time to boot.
How long ? I left it there overnight and it was the same next morning.
IG
Hi @IG ,
It could be a problem with the resources you allocated to the XRv9k. How much resources did you allocate to it? The recommended values are as follow:
Cisco IOS XRv 9000 Router platform
At a very minimum, 10 GB of DRAM and 2 vCPUs are required.
It is recommended to use 16 GB and 4 vCPUs.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
It has nothing to do with the resources.....I have allocated the recommended amount and I have the same problem....
vishal_bhugra
Hello IG,
Were you able to solve the problem. I am having the same problem
