IPSLA in XRv9
Peyman Zadmehr
HI
Whenever I try to configure IPSLA in XRv9 I encountered an error about this feature has no resources and cannot be enabled.
Is there any workaround for this? Is it supported in XRv9?
Thank you
2 Accepted Solutions
I believe only UDP echo is supported not ICMP echo as per the trace below.
RP/0/RP0/CPU0:xrv# show ipsla trace sub-agent initialization
Thu Aug  6 09:25:57.555 UTC
17 wrapping entries (9728 possible, 384 allocated, 0 filtered, 17 total)
Aug  6 09:25:27.784 ipsla/sa/init 0/RP0/CPU0 t18520 Event module IPSLA SA init: Using PD Capabilities:
Aug  6 09:25:27.784 ipsla/sa/init 0/RP0/CPU0 t18520 Event module IPSLA SA caps: ICMP_ECHO=DISABLED
Aug  6 09:25:27.784 ipsla/sa/init 0/RP0/CPU0 t18520 Event module IPSLA SA caps: ICMP_PATHJITTER=DISABLED
Aug  6 09:25:27.784 ipsla/sa/init 0/RP0/CPU0 t18520 Event module IPSLA SA caps: ICMP_PATHECHO=DISABLED
Aug  6 09:25:27.784 ipsla/sa/init 0/RP0/CPU0 t18520 Event module IPSLA SA caps: UDP_JITTER=ENABLED
Aug  6 09:25:27.784 ipsla/sa/init 0/RP0/CPU0 t18520 Event module IPSLA SA caps: UDP_ECHO=ENABLED
Aug  6 09:25:27.784 ipsla/sa/init 0/RP0/CPU0 t18520 Event module IPSLA SA caps: MPLS_LSP_PING=DISABLED
Aug  6 09:25:27.784 ipsla/sa/init 0/RP0/CPU0 t18520 Event module IPSLA SA caps: MPLS_LSP_TRACE=DISABLED
Aug  6 09:25:27.784 ipsla/sa/init 0/RP0/CPU0 t18520 Event module IPSLA SA caps: MPLS_LSP_GROUP=DISABLED
Aug  6 09:25:27.784 ipsla/sa/init 0/RP0/CPU0 t18520 Event module IPSLA SA caps: UDP_JITTER_CHECK_CFG=ENABLED
Aug  6 09:25:27.784 ipsla/sa/init 0/RP0/CPU0 t18520 Event module IPSLA SA caps: UDP_JITTER_MIN_INTERVAL=10
Aug  6 09:25:27.784 ipsla/sa/init 0/RP0/CPU0 t18520 Event module IPSLA SA caps: TWAMP_SERVER=ENABLED
Aug  6 09:25:27.786 ipsla/sa/init 0/RP0/CPU0 t18520 Operation Table module init: complete
Aug  6 09:25:27.786 ipsla/sa/init 0/RP0/CPU0 t18520 Thread Pool module init: complete
Aug  6 09:25:27.796 ipsla/sa/init 0/RP0/CPU0 t18520 Rate Limit module init: Maximum pps rate:15, Minimum interval:70 msec
Aug  6 09:25:27.796 ipsla/sa/init 0/RP0/CPU0 t18520 LSPV Connection module init: complete
Aug  6 09:25:27.796 ipsla/sa/init 0/RP0/CPU0 t18520 Event module init: complete
That is correct, in xrv9k only UDP probes are supported, not ICMP.
Sam
5 Replies 5
smilstea
Can you share the confirmation you were trying to apply and version of xrv9k?
Sam
This is the requested Information:
Thu Aug 6 07:24:02.223 UTC
Cisco IOS XR Software, Version 6.6.2
Copyright (c) 2013-2019 by Cisco Systems, Inc.
Build Information:
Built By : ahoang
Built On : Fri Apr 26 15:47:48 PDT 2019
Built Host : iox-ucs-033
Workspace : /auto/srcarchive16/prod/6.6.2/xrv9k/ws
Version : 6.6.2
cisco IOS-XRv 9000 () processor
System uptime is 2 minutes
RP/0/RP0/CPU0:XRv9(config)#ipsla
RP/0/RP0/CPU0:XRv9(config-ipsla)#operation 1
RP/0/RP0/CPU0:XRv9(config-ipsla-op)#type icmp echo
RP/0/RP0/CPU0:XRv9(config-ipsla-icmp-echo)#destination address 10.10.10.10
RP/0/RP0/CPU0:XRv9(config-ipsla-icmp-echo)#frequency 5
RP/0/RP0/CPU0:XRv9(config-ipsla-icmp-echo)#commit
Thu Aug 6 07:25:13.444 UTC
% Failed to commit one or more configuration items during a pseudo-atomic operation. All changes made have been reverted. Please issue 'show configuration failed [inheritance]' from this session to view the errors
RP/0/RP0/CPU0:XRv9(config-ipsla-icmp-echo)#show configuration failed
Thu Aug 6 07:25:20.212 UTC
!! SEMANTIC ERRORS: This configuration was rejected by
!! the system due to semantic errors. The individual
!! errors with each failed configuration command can be
!! found below.
ipsla
operation 1
type icmp echo
!!% 'ipsla' detected the 'resource not available' condition 'Not supported'
frequency 5
hi
Thank you for the guidance
Sam
