11-01-2018 03:35 AM
Is NV-Cluster/Edge - still supported on the RSP880 ?
Solved! Go to Solution.
11-01-2018 04:16 AM
You can run nv-cluster with RSP880 (RSP-880-LT will not work).
nv cluster is eol
Will not work in 6.x.x. Think 5.3.4 is the last release that supported nv-cluster.
Regards Peter
11-01-2018 04:16 AM
nv cluster is eol
Regards Peter
11-01-2018 05:43 AM
11-01-2018 05:57 AM
11-01-2018 06:21 AM
11-01-2018 05:41 AM
