Is NV-Cluster/Edge - still supported on the RSP880 ?
Peter L
You can run nv-cluster with RSP880 (RSP-880-LT will not work).
nv cluster is eol
https://www.cisco.com/c/en/us/products/collateral/routers/asr-9000-series-aggregation-services-routers/eos-eol-notice-c51-739355.html
Will not work in 6.x.x. Think 5.3.4 is the last release that supported nv-cluster.
Regards Peter
5 Replies 5
Peter L
nv cluster is eol
Regards Peter
Peter,
NV Cluster/Edge isn’t supported on any of the RSP880s.
Eddie.
Sorry for that Eddie. Thought that this was supported as the 880 has the sfp ports. But i guess i learned something new today :)
No problems, yes the SFP EOBC ports are there, but the SW isn’t enabled, we made a business decision to stop supporting the technology from 5.3.4 as you stated correctly.
xr-escalation
No its not supported, if your on NV –Edge we need to work with you to move off that technology, its not supported post released 5.3.4.
Eddie.
