ISM configuration
Hi all!
I have an ISM module and try to use it in our border ASR9000.
vrf insidevrf1
address-family ipv4 unicast
vrf outsidevrf1
hw-module service cgn location 0/7/CPU0
interface GigabitEthernet0/0/0/0
vrf insidevrf1
ipv4 address 10.10.1.1/30
interface ServiceApp1
vrf insidevrf1
ipv4 address 10.111.10.1 255.255.255.0
service cgn CGN1 service-type nat44
interface ServiceApp2
vrf outsidevrf1
ipv4 address 10.111.20.1 255.255.255.0
interface ServiceInfra1
ipv4 address 10.1.1.1 255.255.255.252
service-location 0/7/CPU0
router static
x.x.x.x/29 vrf outsidevrf1 ServiceApp2
vrf insidevrf1
   0.0.0.0/0 ServiceApp1
  10.253.0.0/16 10.10.1.2
vrf outsidevrf1
  x.x.x.x/29 ServiceApp2
service cgn CGN1
service-location preferred-active 0/7/CPU0
service-type nat44 NAT1
  alg ActiveFTP
  inside-vrf insidevrf1
   map outside-vrf outsidevrf1 address-pool x.x.x.x/29
end
In this router BGP is configured too. All BGP routes and interfaces are in vrf default.
And the question. How can I route 0.0.0.0/0 from vrf outsidevrf1 to vrf default?
I can't put any interface in outsidevrf1 because on all interfaces is traffic without NAT too.
If I will create a BVI in vrf default with IP address and will make a static route in it like this:
router static
vrf outsidevrf1
0.0.0.0/0 vrf default BVI1122
Will this work?
asad747
It is not mandatory to create outside vrf , you can directly map outsideserviceapp interface in your CGN configuration which will than do the Global Table lookup for default route.
for exmaple;
service cgn myCGNService
service-location preferred-active 0/2/CPU0
service-type nat44 nat44
  inside-vrf lan-nat-users
   map outsideServiceApp ServiceApp2 address-pool 225.1.1.1/24
asad747
for exmaple;
Thank you!
It's a really great solution!
