05-15-2012 09:40 AM
Hi Team,
I have few questions on ASR 9006
Is ISSU supported on ASR 9006.
Is it hitless or should we expect any packet loss. Also if you have any document or pointer that can walk me through the ISSU process on ASR 9006 , I will really appreciate it. ( I have ISSU document from Nexus and 6500 but want to know is it different or how is it done in ASR 9006)
Azhar
05-15-2012 09:47 AM
Hi Azhar,
ISSU is a framework and includes many different parts, SMUs are one part of it, OS upgrade is another part so i am not sure which one you are referring to exactly.
I would suggest you take your question with your Cisco account team, they would be able to give you more details on the current state of ISSU on ASR9K.
Ahmed
07-02-2012 09:27 AM
Don't understand what you mean SMU ISSU and OS ISSU, for OS we all know should have the ISSU support, but if u install the SMU, for some ones need to reload, for some ones no need.
What do u mean by SMU upgrade ISSU.
Thanks and regards,
Hu Xu
10-22-2013 03:41 AM
You rightly said that there are few SMUs that require the reload of router .
When using ISSU for such a SMU activation ; the traffic hit will be as per ISSU standards and complete traffic will not be brought down (as in case of classic reload when complete router reloads and traffic is down till router boots up )
10-22-2013 03:43 AM
Azhar ,
The following should be useful for you to understand ISSU on ASR9k :
http://www.cisco.com/web/Cisco_IOS_XR_Software/pdf/ISSU_SMUs_Overview.pdf
Please go through the cisco documentation for ISSU on ASR9K . The process is not completely hitless .
