issues installing packages: NCS540-iosxr-k9-6.6.3
ossniper
Hello
I really help. I am trying to install NCS540-iosxr-k9-6.6.3.tar Packages, but keep getting this messages:
PS: I have installed this image on other routers (via cli ) which was successful and working fine, but i am finding it extremely difficult for this particular router(EFI Usb boot). i don't know what could possibly be the problem..
Please what can i do about this and get the packages activated..?
RP/0/RP0/CPU0:ios#install prepare ncs540-ospf-1.0.0.0-r663.x86_64.rpm ncs540-m$
Thu Dec 10 13:10:48.379 UTC
Dec 10 13:10:50 Install operation 18 started by root:
 install prepare pkg ncs540-ospf-1.0.0.0-r663.x86_64.rpm ncs540-mpls-te-rsvp-2.0.0.0-r663.x86_64.rpm ncs540-mpls-1.0.0.0-r663.x86_64.rpm ncs540-mgbl-1.0.0.0-r663.x86_64.rpm ncs540-mcast-2.0.0.0-r663.x86_64.rpm ncs540-li-1.0.0.0-r663.x86_64.rpm ncs540-k9sec-1.0.0.0-r663.x86_64.rpm ncs540-isis-1.1.0.0-r663.x86_64.rpm ncs540-eigrp-1.0.0.0-r663.x86_64.rpm
Dec 10 13:10:51 Package list:
Dec 10 13:10:51   ncs540-ospf-1.0.0.0-r663.x86_64.rpm
Dec 10 13:10:51   ncs540-mpls-te-rsvp-2.0.0.0-r663.x86_64.rpm
Dec 10 13:10:51   ncs540-mpls-1.0.0.0-r663.x86_64.rpm
Dec 10 13:10:51   ncs540-mgbl-1.0.0.0-r663.x86_64.rpm
Dec 10 13:10:51   ncs540-mcast-2.0.0.0-r663.x86_64.rpm
Dec 10 13:10:51   ncs540-li-1.0.0.0-r663.x86_64.rpm
Dec 10 13:10:51   ncs540-k9sec-1.0.0.0-r663.x86_64.rpm
Dec 10 13:10:51   ncs540-isis-1.1.0.0-r663.x86_64.rpm
Dec 10 13:10:51   ncs540-eigrp-1.0.0.0-r663.x86_64.rpm
Dec 10 13:10:59 Install operation will continue in the background
RP/0/RP0/CPU0:ios#Dec 10 13:11:01 Install operation 18 aborted
RP/0/RP0/CPU0:Dec 10 13:11:01.489 UTC: sdr_instmgr[1199]: %INSTALL-INSTMGR-3-OPERATION_ABORT : Install operation 18 aborted
RP/0/RP0/CPU0:ios#install prepare id 6
Thu Dec 10 13:11:38.122 UTC
Dec 10 13:11:39 Install operation 19 started by root:
Dec 10 13:11:40 Package list:
Dec 10 13:11:40   ncs540-isis-1.1.0.0-r663.x86_64
Dec 10 13:11:40   ncs540-mpls-1.0.0.0-r663.x86_64
Dec 10 13:11:40   ncs540-mini-x-6.6.3
Dec 10 13:11:40   ncs540-eigrp-1.0.0.0-r663.x86_64
Dec 10 13:11:40   ncs540-mgbl-1.0.0.0-r663.x86_64
Dec 10 13:11:40   ncs540-mcast-2.0.0.0-r663.x86_64
Dec 10 13:11:40   ncs540-k9sec-1.0.0.0-r663.x86_64
Dec 10 13:11:40   ncs540-ospf-1.0.0.0-r663.x86_64
Dec 10 13:11:40   ncs540-li-1.0.0.0-r663.x86_64
Dec 10 13:11:40   ncs540-mpls-te-rsvp-2.0.0.0-r663.x86_64
Dec 10 13:11:47 Install operation will continue in the background
RP/0/RP0/CPU0:ios#Dec 10 13:11:47 Running image version is same as which is being activated, this is not supported. If you intended to upgrade to different image version , please correct the version and retry the operation
Dec 10 13:11:49 Install operation 19 aborted
RP/0/RP0/CPU0:Dec 10 13:11:49.465 UTC: sdr_instmgr[1199]: %INSTALL-INSTMGR-3-OPERATION_ABORT : Install operation 19 aborted
Grazie,
Osman Akin
tkarnani
Hi.
can we remove the mini from the tar file and just have the RPMS? (Dec 10 13:11:40   ncs540-mini-x-6.6.3)
once you have the .tar file copy it to the disk.
install add source harddisk:/ file.tar
(there is a space between / and f)
install activate id <>  (this will be the same id you get from install add)
lets try this, if it fails please provide show install log reverse/detail
we can check to see why it failed
tkarnani
Hi.
Thanks so much @tkarnani
I really appreciate your help and support.
Its successful and commited
RP/0/RP0/CPU0:ios#install add source harddisk:/ NCS540-iosxr-k9-6.6.3.tar
Thu Dec 10 14:30:38.176 UTC
Dec 10 14:30:40 Install operation 21 started by root:
Dec 10 14:30:47 Install operation will continue in the background
RP/0/RP0/CPU0:ios#Dec 10 14:31:40 It is a NO IMPACT OPERATION as all packages have already been added
Dec 10 14:31:42 Install operation 21 finished successfully
RP/0/RP0/CPU0:Dec 10 14:31:42.742 UTC: sdr_instmgr[1199]: %INSTALL-INSTMGR-2-OPERATION_SUCCESS : Install operation 21 finished successfully
RP/0/RP0/CPU0:ios#install activate id 21
Thu Dec 10 14:33:17.147 UTC
Dec 10 14:33:19 Install operation 22 started by root:
Dec 10 14:33:19 Package list:
Dec 10 14:33:19 ncs540-isis-1.1.0.0-r663.x86_64
Dec 10 14:33:19 ncs540-mpls-1.0.0.0-r663.x86_64
Dec 10 14:33:19 ncs540-eigrp-1.0.0.0-r663.x86_64
Dec 10 14:33:19 ncs540-mgbl-1.0.0.0-r663.x86_64
Dec 10 14:33:19 ncs540-mcast-2.0.0.0-r663.x86_64
Dec 10 14:33:19 ncs540-k9sec-1.0.0.0-r663.x86_64
Dec 10 14:33:19 ncs540-ospf-1.0.0.0-r663.x86_64
Dec 10 14:33:19 ncs540-li-1.0.0.0-r663.x86_64
Dec 10 14:33:19 ncs540-mpls-te-rsvp-2.0.0.0-r663.x86_64
Dec 10 14:33:56 Install operation will continue in the background
RP/0/RP0/CPU0:ios#
* The idle timeout is soon to expire on this line
RP/0/RP0/CPU0:ios#sh install requ
Thu Dec 10 14:47:26.387 UTC
User root, Op Id 22
install activate
The install operation 22 is 86% complete.
Activating package 9 (ncs540-k9sec-1.0.0.0-r663.x86_64)
Node(s) State %Completed Action
Node 0/RP0/CPU0 : Completed 100% Software change complete
Node 0/0/CPU0 : Completed 100% Software change complete
RP/0/RP0/CPU0:ios#sh install active
Thu Dec 10 14:47:36.495 UTC
RP/0/RP0/CPU0:Dec 10 14:47:36.933 UTC: sdr_instmgr[1199]: %INSTALL-INSTMGR-2-OPERATION_SUCCESS : Install operation 22 finished successfully
Install operation is in progress.
Please use 'show install request' to monitor the status.
RP/0/RP0/CPU0:ios#sh install inactive
Thu Dec 10 14:47:57.121 UTC
1 inactive package(s) found:
ncs540-mini-x-6.6.3
Thu Dec 10 14:48:30.788 UTC
Node 0/RP0/CPU0 [RP]
Boot Partition: xr_lv0
Active Packages: 10
ncs540-xr-6.6.3 version=6.6.3 [Boot image]
Node 0/0/CPU0 [LC]
Boot Partition: xr_lcp_lv0
Active Packages: 10
