NCS-55A2-MOD-SE-S chassis with NC55-930W-DCFW
esantana1
Need clarification on power installation requirements for NCS-55A2-MOD-SE-S chassis with NC55-930W-DCFW power units.  Need documentation, which states the fuse power panel requirements.
Also ordered CAB-48DC-40A-8AWG (C-Series -48VDC PSU Power Cord, 3.5M, 3 Wire, 8AWG, 40A)  What type of connector does this cable have on the power panel termination side, or is it just bare wire.
There are some details on NCS-950W-DCFW, however I could not get fusing/power panel requirements for the NCS-930W-DCFW?
Thanks in Advance
tkarnani
there is some of this information in the install guide
https://www.cisco.com/c/en/us/td/docs/iosxr/ncs5500/hardware-install/b-ncs5500-hardware-installation-guide-fixed-port/b-ncs5500-hardware-installation-guide-fixed-port_chapter_011.html#task_022B072A0CBF43EEA32C8dcpowerncs1000
Before installing a DC power supply to the switch, you will need to attach DC connection wires that you provide to the DC power connector included in the DC power supply's accessory kit. For 240-380 VDC power supply, the dual-pole breaker or fuse rating is 20 A. For 40-72 VDC power supply, the single breaker or fuse is 40 A.
tkarnani
Yes, I did see that documentation with requirements for the NCS-950W-DCFW.
Thanks for verifying that is the same for NCS-930W-DCFW.
Thanks You!
