logging discriminator on ASR903
mcagiola
Hi all,
I'm facing on a configuration of logging discriminator on asr903, but... it doesn't works!
My configuration is that:
logging discriminator TEST msg-body drops "LINK"
logging buffered discriminator TEST
Off course this is a tests configuration and I want to filter on the buffer this log:
Mar 10 16:02:34.960: %LINK-3-UPDOWN: Interface TenGigabitEthernet0/4/0, changed state to down
Even if the discriminator is on:
ASR903-4-525-AC302#sh log
Syslog logging: enabled (0 messages dropped, 10 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
Active Message Discriminator:
The logs are not... discriminated.
The image that i'm using is  Version 15.6(2)S.
Thanks.
Marco
dan.cicioiu
Hi Marco,
You should have the matching string without quotes.
Like :
logging discriminator TEST msg-body drops LINK
Kind Regards,
Dan
