MPA disabled after RSP upgrade
Ahmed Ash
greeting
after upgrading the RSP from 440 to 880 and rebooting the device i had an issue where one of MPA started showing disabled
A9K-MPA-4X10GE DISABLED NPWR,NSHUT,MON
which was working normally before the reboot.
after changing the MPA to another LC its working normally so the issue appears in the sub LC slot whatever MPA inserted will be disabled
some logs
lda_server[64]: %L2-SPA-5-STATE_CHANGE : SPA in bay 1 type A9K-MPA-4x10GE Initing
shelfmgr[432]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/0/1 A9K-MPA-4X10GE state:INITIALIZED
invmgr[269]: %PLATFORM-INV-6-NODE_STATE_CHANGE : Node: 0/0/1, state: FAILED
shelfmgr[432]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/0/1 A9K-MPA-4X10GE state:IN-RESET
 invmgr[269]: %PLATFORM-INV-6-INTF_OIRIN : xFP OIR: TenGigE0/0/1 port_num: 0 Sn: ONT181502E5 is inserted, state: 1
 lda_server[64]: %L2-SPA-5-STATE_CHANGE : SPA in bay 1 type A9K-MPA-4x10GE Resetting
shelfmgr[432]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/0/1 A9K-MPA-4X10GE state:NOT-PRESENT
invmgr[269]: %PLATFORM-INV-6-NODE_STATE_CHANGE : Node: 0/0/1, state: UNPOWERED
shelfmgr[432]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/0/1 UNKNOWN state:UNPOWERED
 invmgr[269]: %PLATFORM-INV-6-INTF_OIROUT : xFP OIR: TenGigE0/0/1 port_num: 0 Sn: ONT181502E5 is removed, state: 0
shelfmgr[432]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/0/1 A9K-MPA-4X10GE state:POWER UP
lda_server[64]: %L2-SPA-5-OIR_ERROR : SPA (1): A SPA hardware or software error occurred, please contact technical support
 invmgr[269]: %PLATFORM-INV-6-NODE_STATE_CHANGE : Node: 0/0/1, state: DISABLED
5 Replies 5
tkarnani
Hi Ahmed,
have you tried reloading the entire LC1 and seeing if the MPA comes back online?
based on your troubleshooting you tried the MPA in another router and it is working.
I tried OIR for the mod80 which the MPA was inserted, reloading the whole chase after FPD upgrade.
still showing disabled
Hi Ahmed,
do you have another MPA, just to check if that slot is good?
thanks
yup i tried another MPA showing disabled as well
Hi Ahmed,
i would suggest opening a tac case, seems like a faulty slot. not sure why the upgrade triggered it
