MPLS LDP - NSR N/A
Pedro Morais
Hello all,
After upgrading an ASR9K from 4.0.1 to 4.2.3 I noticed that NSR didn't came up, showing N/A in the output of "sh mpls ldp neighbor brief":
RP/0/RSP0/CPU0:A9K-LAB01#sh mpls ldp neighbor brief
Fri Jan  4 14:19:52.393 WET
Peer               GR  NSR  Up Time     Discovery  Address  IPv4 Label
172.25.200.7:0     Y   Y    6w2d                2        3          10 <- IOS
172.25.200.2:0     Y   Y    3w4d                3       12          10 <- IOS
172.25.200.10:0    Y   Y    2w0d                2        4          31 <- IOS-XR 4.0.1
172.25.200.11:0    Y   N/A  20:55:55            1        4          31 <- IOS-XR 4.2.3
172.25.200.6:0     Y   N/A  02:08:11            1        7          31 <- IOS-XR 4.2.3
172.25.200.15:0    Y   N/A  00:12:37            2        3          31 <- IOS-XR 4.2.3
Routers have connectivity to each other, and configurations are pretty much the same in all of them:
RP/0/RSP0/CPU0:A9K-LAB01#sh run mpls ldp
Fri Jan  4 15:45:12.164 WET
mpls ldp
router-id 172.25.200.5
discovery hello holdtime 45
discovery hello interval 15
nsr
graceful-restart
backoff 5 10
holdtime 80
session protection
neighbor 172.25.200.2 password encrypted
neighbor 172.25.200.7 password encrypted
neighbor 172.25.200.10 password encrypted
neighbor 172.25.200.15 password encrypted
igp sync delay 10
label
  allocate for LLAF
log
  neighbor
  graceful-restart
  session-protection
  nsr
interface GigabitEthernet0/4/0/0.2
interface TenGigE0/0/0/1.2
interface TenGigE0/0/0/2.2
interface TenGigE0/1/0/0.2
interface TenGigE0/1/0/1.2
When debugging "mpls ldp nsr" in 4.2.3 I don't see any event, however in 4.0.1 I can see all the events. Anyone could help me to go further in my troubleshooting?
Pedro
Alexei Kiritchenko
Hello Pedro,
may you look at show mpls ldp neighbour output and verify if these are targeted LDP sessions?
NSR on targeted LDP is supported from 4.3.0.
/A
6 Replies 6
Alexei Kiritchenko
Hello Pedro,
/A
Thx Alexei,
Yes, I'm aware of that detail, however this are directly connected routers.
Any other idea?
Pedro
Hi Pedro,
Do you have l2vpn between these directly connected rotuers for example? If so, then even on these directly connected links we run targeted ldp and hence no NSR.
Here is the example from my lab on a directly connected link:
RP/0/RSP0/CPU0:sisters#show mpls ldp neighbor brief
Mon Jan  7 13:55:10.143 CET
138.187.93.66:0    Y   N/A  1w5d                2       25          89
10.0.1.25:0        Y   Y    4d02h               2       24          81
RP/0/RSP0/CPU0:sisters#show mpls ldp neighbor 138.187.93.66
Mon Jan  7 13:55:29.449 CET
Peer LDP Identifier: 138.187.93.66:0
  TCP connection: 138.187.93.66:49647 - 138.187.93.64:646
  Graceful Restart: Yes (Reconnect Timeout: 120 sec, Recovery: 0 sec)
  Session Holdtime: 180 sec
  State: Oper; Msgs sent/rcvd: 20234/20274; Downstream-Unsolicited
  Up time: 1w5d
  LDP Discovery Sources:
    TenGigE0/2/0/0
    Targeted Hello (138.187.93.64 -> 138.187.93.66, active)
RP/0/RSP0/CPU0:sisters#show running-config l2vpn
Mon Jan  7 13:55:42.462 CET
l2vpn
xconnect group XX
  p2p YY
   interface Bundle-Ether9400.91040
   neighbor 138.187.93.66 pw-id 901040
/A
Hi Alexei,
Yes, we do have L2 VPNs between those routers. Also, I checked the output of "show mpls ldp neighbor" and targeted ldp is running in all of them. That is what got me confused. I believe that we might be facing any kind of cosmetic bug in the routers running 4.0.1...
Mon Jan  7 15:02:07.376 WET
172.25.200.11:0    Y   N/A  2d23h               1        4          31
172.25.200.2:0     Y   Y    2d23h               3       12          10
172.25.200.7:0     Y   Y    2d23h               2        3          10
172.25.200.10:0    Y   Y    2d23h               2        4          31  <- 4.0.1
172.25.200.6:0     Y   N/A  2d20h               1        7          31  <- 4.2.3
172.25.200.15:0    Y   N/A  02:15:40            2        3          31
Mon Jan  7 15:02:18.219 WET
Peer LDP Identifier: 172.25.200.11:0
  TCP connection: 172.25.200.11:19136 - 172.25.200.5:646
  Graceful Restart: Yes (Reconnect Timeout: 120 sec, Recovery: 180 sec)
  Session Holdtime: 80 sec
  State: Oper; Msgs sent/rcvd: 11180/11165; Downstream-Unsolicited
  Up time: 2d23h
    Targeted Hello (172.25.200.5 -> 172.25.200.11, active)
  Addresses bound to this peer:
    172.25.7.36      172.25.7.94      172.25.7.161     172.25.200.11
Peer LDP Identifier: 172.25.200.2:0
  TCP connection: 172.25.200.2:646 - 172.25.200.5:29821; MD5 on
  State: Oper; Msgs sent/rcvd: 11129/11093; Downstream-Unsolicited
  Up time: 2d23h
    TenGigE0/1/0/0.2
    TenGigE0/0/0/1.2
    Targeted Hello (172.25.200.5 -> 172.25.200.2, active)
    172.25.7.25      172.25.7.81      172.25.7.85      172.25.7.101
    172.25.7.113     172.25.7.121     172.25.7.125     172.25.7.153
    172.25.7.157     172.25.7.173     172.25.7.177     172.25.200.2
Peer LDP Identifier: 172.25.200.7:0
  TCP connection: 172.25.200.7:39798 - 172.25.200.5:646; MD5 on
  Graceful Restart: Yes (Reconnect Timeout: 120 sec, Recovery: 120 sec)
  State: Oper; Msgs sent/rcvd: 11133/11086; Downstream-Unsolicited
  Up time: 2d23h
    Targeted Hello (172.25.200.5 -> 172.25.200.7, active)
    172.25.7.106     172.25.7.110     172.25.200.7
Peer LDP Identifier: 172.25.200.10:0
  TCP connection: 172.25.200.10:41025 - 172.25.200.5:646; MD5 on
  State: Oper; Msgs sent/rcvd: 11125/11133; Downstream-Unsolicited
  Up time: 2d23h
    TenGigE0/0/0/2.2
    Targeted Hello (172.25.200.5 -> 172.25.200.10, active)
    172.25.7.34      172.25.7.90      172.25.7.97      172.25.200.10
Peer LDP Identifier: 172.25.200.6:0
  TCP connection: 172.25.200.6:25373 - 172.25.200.5:646
  State: Oper; Msgs sent/rcvd: 11349/12751; Downstream-Unsolicited
  Up time: 2d20h
    Targeted Hello (172.25.200.5 -> 172.25.200.6, active)
    172.25.7.31      172.25.7.86      172.25.7.93      172.25.7.109
    172.25.7.169     172.25.7.178     172.25.200.6
Peer LDP Identifier: 172.25.200.15:0
  TCP connection: 172.25.200.15:63213 - 172.25.200.5:646; MD5 on
  State: Oper; Msgs sent/rcvd: 384/384; Downstream-Unsolicited
  Up time: 02:15:51
    TenGigE0/1/0/1.2
    Targeted Hello (172.25.200.5 -> 172.25.200.15, active)
    172.25.7.166     172.25.7.170     172.25.200.15
Any place in the documentation were I can found more info about targeted LDP?
Pedro
Yes, indeed, officially NSR is not supported on targeted LDP, so even if it works, we can consider it as a bonus
There is not much difference between LDP and tLDP.  tLDP neighbour discovery differs from normal discovery only in the addressing of hello packets. Hello packets use unicast IP addresses instead of multicast addresses. When a neighbour is discovered, the mechanism to establish a session is the same.
/A
Thx for your help Alexei!!!
