NCS 540 Insert SFP 1gb/s in interface 25gb/s
a.auvinet
I test one NCS 540 in my lab.
I have 24 interfaces TenGiga , 8 twentyfiveGiga  and 4 100gb.
In documentation, i can see interface  twentyfiveGiga  are Ok for 1Gb.
https://www.cisco.com/c/en/us/products/collateral/routers/network-convergence-system-500-series-routers/datasheet-c78-740296.html
When I insert a SFP 1 Gbs in interface tengiga, It seems OK, the NCS540 create a gigabit interface.
Not When I insert in twentyfiveGiga.
Someone have a idea ?
philclemens1835
I suspect the documentation is incorrect.
As I understand it, the NCS platform is based on merchant silicon from Broadcom.
If you look at Broadcom's material for SFP28 interfaces, it only states backwards compatibility with SFP+ 10Gbps, and not 1Gbps.  I found this in a few different SFP28 educational-type articles as well.
If there is backwards compatibility to 1Gbps, it would likely be based on a specific SFP model.  Something along the lines of an SFP+ that is stepped down to 1Gbps.  Much like Cisco makes 100BaseFX SFP's for gigabit interfaces (GLC-GE-100FX vs GLC-FE-100FX).
philclemens1835
hi philclemens.
thank you for your reply.
I just find this link on the web
http://networkingbodges.blogspot.com/2019/03/how-to-use-25g-ports-in-110g-mode-on.html?m=1
I try it asap
and reply to you for your information
best regard
Hi Everybody,
I configured the Twentyfive   to ten .
The interface  25 to 31 is now 10g.
hw-module quad 0 location 0/0/CPU0
 mode 10g
hw-module quad 1 location 0/0/CPU0
 mode 10g
But when I insert a SFP  1g in Interface between 0 > 24 , it is OK, it's UP
But when I insert a SFP  1g in Interface between  25 > 31, it is NOK, it's still Down
Exemple of configuration of interface :
interface GigabitEthernet0/0/0/22
 speed 1000
 negotiation auto
interface GigabitEthernet0/0/0/28
 speed 1000
 negotiation auto
