Output Drop by RESOLVE_VPLS_REFLECTION_FILTER_DROP_CNT
Hello!
How i can determine a reason of output drops?
>sh inter tenGigE 0/0/0/6
Fri Nov  2 15:26:05.358 MSK
TenGigE0/0/0/6 is up, line protocol is up
  Interface state transitions: 11
  Hardware is TenGigE, address is 108c.cf1d.f326 (bia 108c.cf1d.f326)
  Layer 1 Transport Mode is LAN
  Description: To_XXX
  Internet address is 10.1.11.77/30
  MTU 9194 bytes, BW 10000000 Kbit (Max: 10000000 Kbit)
     reliability 255/255, txload 2/255, rxload 5/255
  Encapsulation ARPA,
  Full-duplex, 10000Mb/s, LR, link type is force-up
  output flow control is off, input flow control is off
  loopback not set,
  ARP type ARPA, ARP timeout 04:00:00
  Last input 00:00:00, output 00:00:00
  Last clearing of "show interface" counters 50w1d
  30 second input rate 218575000 bits/sec, 41199 packets/sec
  30 second output rate 115545000 bits/sec, 30555 packets/sec
     481020016118 packets input, 287815762466192 bytes, 876403 total input drops
     0 drops for unrecognized upper-level protocol
     Received 29 broadcast packets, 39255653 multicast packets
              0 runts, 17 giants, 0 throttles, 0 parity
     17 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     368901547057 packets output, 180820085800502 bytes, 28931652 total output drops
     Output 5 broadcast packets, 39284266 multicast packets
     0 output errors, 0 underruns, 0 applique, 0 resets
     10 carrier transitions
>show controllers np counters np7  location 0/0/CPU0 | i DROP
Fri Nov  2 15:27:03.815 MSK
  31  PARSE_INGRESS_DROP_CNT                                849353           0
  32  PARSE_EGRESS_DROP_CNT                                1236171           0
  33  RESOLVE_INGRESS_DROP_CNT                              868559           0
  34  RESOLVE_EGRESS_DROP_CNT                           3636654813         293
  37  MODIFY_EGRESS_DROP_CNT                                   669           0
  84  RESOLVE_AGE_NOMAC_DROP_CNT                                 1           0
  85  RESOLVE_AGE_MAC_STATIC_DROP_CNT                    187392316           8
371  MPLS_PLU_DROP_PKT                                          1           0
468  RESOLVE_VPLS_SPLIT_HORIZON_DROP_CNT                 28931887           6
469  RESOLVE_VPLS_REFLECTION_FILTER_DROP_CNT           3293536501         272
481  RESOLVE_L2_EGR_PW_UIDB_MISS_DROP_CNT                       4           0
491  RESOLVE_VPLS_EGR_PW_FLOOD_UIDB_DOWN_DROP_CNT                 1           0
499  RESOLVE_MAC_NOTIFY_CTRL_DROP_CNT                   313463638          16
500  RESOLVE_MAC_DELETE_CTRL_DROP_CNT                     1591242           0
622  EGR_DHCP_PW_UNTRUSTED_DROP                           1236171           0
Input drops by RESOLVE_VPLS_REFLECTION_FILTER_DROP_CNT was considered at https://supportforums.cisco.com/thread/2099283
But how we can apply it for output?
Vadim Zhovtanyuk
Ji Albert,
I would clear cpunters on interface and NP level and then capture again the outputs
sh controller tenGigE 0/0/0/6  all
3-4 tmies in a row with about 1 minute interval to se which counters are incrementing.
normally is related in ingress drops and we have some input drops,
but we don't see any ino about output drops on controler level and we mayneed to check them as well
wbr
/vz
Last column at "show controllers np counters np7  location 0/0/CPU0 | i DROP" is a pps. So we see 293pps
RESOLVE_EGRESS_DROP_CNT and 0pps RESOLVE_INGRESS_DROP_CNT. Therefore RESOLVE_VPLS_REFLECTION_FILTER_DROP_CNT is a part of RESOLVE_EGRESS_DROP_CNT, aren't it?
Also, counters egress_drop are increases, but ingress_drop are not:
  34  RESOLVE_EGRESS_DROP_CNT                           3637707596         149
469  RESOLVE_VPLS_REFLECTION_FILTER_DROP_CNT           3294483194         129
And one minute later:
  34  RESOLVE_EGRESS_DROP_CNT                           3637718845         156
469  RESOLVE_VPLS_REFLECTION_FILTER_DROP_CNT           3294492975         135
Also no new input drops at "sh inter":
sh inter tenGigE 0/0/0/6 | i drops
Fri Nov  2 16:57:39.828 MSK
     481200652943 packets input, 287931866783215 bytes, 876403 total input drops
     369034005321 packets output, 180881208804090 bytes, 28963679 total output drops
One minute later:
Fri Nov  2 16:59:23.441 MSK
     481203274011 packets input, 287933491017363 bytes, 876403 total input drops
     369035900847 packets output, 180882007120600 bytes, 28964280 total output drops
Hi Albert,
Which XR release you are running?
Becaue of the CSCtx92242
RESOLVE_VPLS_REFLECTION_FILTER_DROP_CNT are not counted as the part of the interface drops till 4.2.2
So, if you are running anything below then 4.2.2
RESOLVE_VPLS_REFLECTION_FILTER_DROP_CNT will no be counted as part of the drops on the interface level.
Again, this NP counters is for the ingress unicast VPLS frame that has a source XID that matches its  destination XID.   These are dropped since it cannot be sent back to the  source port.
Since the inpt drop counters on the interface is not increasing I assume you are running something lower then 4.2.2 and then the reason for output drops on the interface level is
The diffs between two captures on the interface is 601 for total output drops for aprox. 104 sec so the rate for the output drops is aprox. 6 pps which is far below then
and
And again, the last one is related to ingress frames , so i would check the controller counters on the affected interface first and then go to check bridge and fia counters on LC.
wbr
/vadim
