ASR 9010 init: 'flashdrvr' abCisco IOS XR Sofnormally terminated
La Quy Phai
Hi Team
i have a case want dissus with all of team. i have 3 ASR 9010 devices with dual RSP-4G, but i can't understand why all of them has rebooting problem.
Last week, we must cut off the electric system but we forgot power off the device, and after that, it restart and the second RSP can't boot IOS XR software.
i tried other way in rommon mode, but nothing changes. I think this RSP have problem and need replace new one.
Here some output console logging when it rebooting,  please check and recommend me some ideas about it.
POST 3 : PASSED : code 0 : Slot ID/Board Type Validity
PCI-E1: Ready as Root Complex
PCI-E2: Ready as Root Complex
set_chassis_type: chassis_type=0xef02fe found=TRUE
ASR9K (8641D PPC) platform with 4096 Mb of main memory
program load complete, entry point: 0x100000, size: 0x2ac20
MBI Candidate = disk0:asr9k-os-mbi-3.9.2/mbiasr9k-rp.vm
    CARD_SLOT_NUMBER: 5
        CPU_INSTANCE: 1
MBI Validation starts ...
Mgt LAN 0 interface is selectedInterface link changed state to UP.
Interface link state up.
MBI validation sending request.
HIT CTRL-C to abort
No MBI confirmation received from dSC
AUTOBOOT: Boot string = disk0:asr9k-os-mbi-3.9.2/mbiasr9k-rp.vm,1;
AUTOBOOT: autobootstate=0, autobootcount=0, cmd=boot disk0:asr9k-os-mbi-3.9.2/mbiasr9k-rp.vm
MBI size from header = 11371848,Bootflash resident MBI filesize = 11371848
program load complete, entry point: 0x1fcf28, size: 0xad7648
Attempting to start second CPU
SMP initialized.
Config = SMP, Running = SMP
BSP: Board type : RO-RSP2
tracelogger: starting tracing in background ring mode
tracelogger running with args: -startring -F 1 -F 2
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagiraph
(c) of then Commercial Compiuter Software - tRestricted
Righ:ts clause at FAR  sec. 52.227-19 'flashdrvrand subparagraph'
(c) (1) (ii) o abnormally f the Rights in tTechnical Data aerminated, rnd Computer
Sofespawn count 1 (1,1,256)
tware clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
    init: 'flashdrvr' abnormally terminated, respawn count 2 (1,1,256)
       170 West Tasman Drive
           San Jose, California 95134-1706
init: 'flashdrvr' abCisco IOS XR Sofnormally terminated, respawn count 3 (1,1,256)
tware for the Cisco XR ASR9K, Version 3.9.2
Copyright (c) 2009 by Cisco Systems, Inc.
init: 'flashdrvr' abnormally terminated, respawn count 4 (1,1,256)
init: respawn 'flashdrvr' disabled, INIT_MAX_SPAWN reached (1)
Writing crashinfo
Active processes:
        asr9k-os-3.9.2/bin/init Thread ID 2 on cpu 0
Active processes:
        pkg/bin/i2c-master Thread ID 0 on cpu 1
[0x05b654b63] Record Reboot History, reboot cause = 0x2c000007, descr = Cause: LITE: respawn 'flashdrvr' disabled, exit_code 256, INIT_MAX_SPAWN reached Process: init        Traceback: 4c0d6a78 4[0x05db3c6be] Record crashinfo
[0x05e01b8ff] Record Syslog
1970-01-01 00:00:08.771
NOTE: This is NOT a Kernel Crash. This crash was triggered
      by the process 'init', by calling reboot API.
Crash Reason: Cause: LITE: respawn 'flashdrvr' disabled, exit_code 256, INIT_MAX_SPAWN reached Process: init        Traceback: 4c0d6a78 4c0d6c88 40007324 4c0ef17c 4c0e9d34 400037c4 (Cause Code: 0x2c000007)
Exception at 0x4c0d6d1c signal 5 c=1 f=3
Active process(s):
       REGISTER INFO
        r0        r1        r2        r3
  R0   4c0d6d70  9bf5ddb0  5000f180  00000000
        r4        r5        r6        r7
  R4   00000000  00000000  9bf5dd88  00000000
        r8        r9       r10       r11
  R8   540be400  00000000  2de4ddba  00000000
       r12       r13       r14       r15
  R12  50004e23  5000f180  00000000  00000000
       r16       r17       r18       r19
  R16  00000000  00000000  00000000  00000000
       r20       r21       r22       r23
  R20  50006f10  50000000  50007678  50000000
       r24       r25       r26       r27
  R24  9bf5def0  00000000  9bf5df58  50000000
       r28       r29       r30       r31
  R28  ec010000  9bf5ddbc  ec00b884  00000000
       cnt        lr       msr        pc
  R32  4c04e298  4c0d6d70  0002d932  4c0d6d1c
       cnd       xer
  R36  24004088  00000000
               SUPERVISOR REGISTERS
              Memory Management Registers
              Instruction BAT Registers
               Index #                Value
              IBAT0U #             0x1ffe
              IBAT0L #               0x12
              IBAT1U #                  0
              IBAT1L #                  0
              IBAT2U #                  0
              IBAT2L #                  0
              IBAT3U #         0xfffc0003
              IBAT3L #            0x40011
              IBAT4U #         0x4c0007ff
              IBAT4L #         0x74000011
              IBAT5U #                  0
              IBAT5L #                  0
              IBAT6U #                  0
              IBAT6L #                  0
              IBAT7U #                  0
              IBAT7L #                  0
              Data BAT Registers
               Index #                Value
              DBAT0U #             0x1ffe
              DBAT0L #               0x12
              DBAT1U #         0x34000002
              DBAT1L #         0xdc00002a
              DBAT2U #         0x3000001e
              DBAT2L #         0xc800002a
              DBAT3U #         0xfffc0003
              DBAT3L #            0x40011
              DBAT4U #         0x4c0007ff
              DBAT4L #         0x74000011
              DBAT5U #                  0
              DBAT5L #                  0
              DBAT6U #                  0
              DBAT6L #                  0
              DBAT7U #                  0
              DBAT7L #                  0
              Exception Handling Registers
       Data Addr Reg #                DSISR
        0x6012c000 #         0x40000000
     SPRG0 #      SPRG1 #      SPRG2 #      SPRG3
       0 # 0xec00b884 # 0x9bf5ddbc #        0
   SaveNRestore SRR0 #    SaveNRestore SRR1
        0x4c0d6d18 #            0x2d932
              Miscellaneous Registers
    Processor Id Reg #                  0
                HID0 #         0x8493c1bc
                HID1 #            0x2cc80
              MSSCR0 #             0x8000
              MSSSR0 #                  0
STACK TRACE
#0 0x4c0d6d70
[0x0803a457a] Initializing harddisk file system
[0x08495b4dc] Record TSEC information
Writing TSEC done
Writing crashinfo done!
Examine crashinfo file for reboot reason
Writing ppc kernel core file
[0x0862d199f] Kernel core dump start...
fill phdr vaddr=0xfe8a000, offset=0x34fd494, size=0x176000
Core dump success. Total_size 57095316
[0x09386311e] Successfully dumped Kernel core
[0x093ef1f47] Record PCDS information
Writing PCDS done
Dump Directory
KD: RSP1.700101-000008.tsec, start = 1000, size = 4000, crc = 0
KD: RSP1.700101-000008.crashinfo.by.init, start = 5000, size = ae5a, crc = 0
KD: RSP1.700101-000008.kernel_core.by.init.Z, start = 10000, size = 25f5d3, crc = 22f228a4
KD: RSP1.700101-000008.pcds, start = 270000, size = ff000, crc = 18ff3d46
Writing kernel core file done!
rebooting
Vadim Zhovtanyuk
Hello  Phai
first of all it would be really good if you can raise TAC sr tp record and torubleshoot the issue
You need to provide
-the full console log
-sh ver
-admin show platform
and dumpcore file
It looks like you are having hte issue with flash and it is not possible for the system to intitialze
flashdrvr process, so yes, the replacement seems to be the way to recover
But again, better raise the TCA SR and decode the traceback
wbr
/vz
