PLATFORM-FCA-2-TX_RX_TIMEOUT on ASR9010
roinbeltran
Anyone experience receiving below syslog? What would be the cause of this? Thanks in advance
LC/0/1/CPU0:Apr 11 16:38:10.172 : pfm_node_lc[305]: %PLATFORM-FCA-2-TX_RX_TIMEOUT : Clear|lda_server[36897]|0x1032006|Device driver for device 'Tom_POLLER6' detected IO timeout on '(null)'. Timeout address 0x401d807c. Timeout access 0xb4.
LC/0/1/CPU0:Apr 11 16:38:15.340 : pfm_node_lc[305]: %PLATFORM-FCA-2-TX_RX_TIMEOUT : Set|lda_server[36897]|0x1032006|Device driver for device 'Tom_POLLER6' detected IO timeout on '(null)'. Timeout address 0x40b2a07c. Timeout access 0xb4.
LC/0/1/CPU0:Apr 11 16:38:16.339 : pfm_node_lc[305]: %PLATFORM-FCA-2-TX_RX_TIMEOUT : Clear|lda_server[36897]|0x1032006|Device driver for device 'Tom_POLLER6' detected IO timeout on '(null)'. Timeout address 0x40b2a07c. Timeout access 0xb4.
LC/0/1/CPU0:Apr 11 16:38:20.592 : pfm_node_lc[305]: %PLATFORM-FCA-2-TX_RX_TIMEOUT : Set|lda_server[36897]|0x1032006|Device driver for device 'Tom_POLLER6' detected IO timeout on '(null)'. Timeout address 0x40abf07c. Timeout access 0xb4.
LC/0/1/CPU0:Apr 11 16:38:21.349 : pfm_node_lc[305]: %PLATFORM-FCA-2-TX_RX_TIMEOUT : Clear|lda_server[36897]|0x1032006|Device driver for device 'Tom_POLLER6' detected IO timeout on '(null)'. Timeout address 0x40abf07c. Timeout access 0xb4.
tkarnani
the lda_server process is having trouble reading EEPROM information off an optic on line card 1
please check the following output to see which port is reporting the issue.
show controllers lda trace reverse verbose location 0/1/CPU0
you should see something like this;
Failed to get compressed port EEPROM data (0x46428600: 'fca' detected the 'warning' condition 'The protocol/capsulation/interface could not be found') <TP37:#0x6#>
Dec 21 02:38:36.023 lda/svr/errors 0/2/CPU0 t4795 PID=[4795]<10269:lda_pwg_get_port_cmp_eeprom>: ERROR: Inst 11; Failed to get port EEPROM data (0x46428600: 'fca' detected the 'warning' condition 'The protocol/capsulation/interface could not be found') <TP36:#0x5#>
tkarnani
roinbeltran
Hi tkarnani
Here is the output for show controllers lda trace reverse verbose location 0/1/CPU0
May 2 10:50:54.421 lda/svr/info 0/1/CPU0 t11 laguna[36897]<61:lda_irpt_os_interrupt_unmask>: INFO: Inst 206; interrupt mask count matched (0x00000000) <TP26:#0xd7dee#>
May 2 10:50:54.421 lda/svr/info 0/1/CPU0 t11 laguna[36897]<285:lda_api_irpt_hdlr>: INFO: Inst 206; LDA IRPT; code:0x0000007f value:0x00000000 irq:0x000000ce, state:4, enable 0, handle aa7ca2c (0x00000000) <TP26:#0xd7ded#>
May 2 10:50:54.420 lda/svr/debugs 0/1/CPU0 t1 laguna[36897]<7180:lda_pwg_get_i2cafp_ctx>: INFO: Bay/Port: 6/1; INST/CHAN uses p_i2cafp_ctx Tom_POLLER6 inst 6, dev 2, chain 0, log_id 6, ports/poll 6, num poll 8, present 2, block type = (0x00000032) <TP27:#0x2861d5#>
May 2 10:50:54.420 lda/svr/debugs 0/1/CPU0 t1 laguna[36897]<7180:lda_pwg_get_i2cafp_ctx>: INFO: Bay/Port: 7/0; INST/CHAN uses p_i2cafp_ctx Tom_POLLER7 inst 7, dev 2, chain 0, log_id 7, ports/poll 6, num poll 8, present 0, block type = (0x00000032) <TP27:#0x2861d4#>
May 2 10:50:54.420 lda/svr/errors 0/1/CPU0 t11 <6:LOC>: LDA FMEA TIMEOUT ERR bus (6) fpga (2) to_addr (0x40b2a07c) to_access (0xb4) <TP211:#0x47cf6#>
May 2 10:50:54.419 lda/svr/debugs 0/1/CPU0 t1 laguna[36897]<7180:lda_pwg_get_i2cafp_ctx>: INFO: Bay/Port: 6/0; INST/CHAN uses p_i2cafp_ctx Tom_POLLER6 inst 6, dev 2, chain 0, log_id 6, ports/poll 6, num poll 8, present 2, block type = (0x00000032) <TP27:#0x2861d3#>
May 2 10:50:54.419 lda/svr/debugs 0/1/CPU0 t1 laguna[36897]<7180:lda_pwg_get_i2cafp_ctx>: INFO: Bay/Port: 5/0; INST/CHAN uses p_i2cafp_ctx Tom_POLLER5 inst 5, dev 2, chain 0, log_id 5, ports/poll 6, num poll 8, present 0, block type = (0x00000032) <TP27:#0x2861d2#>
May 2 10:50:54.419 lda/svr/debugs 0/1/CPU0 t1 laguna[36897]<7180:lda_pwg_get_i2cafp_ctx>: INFO: Bay/Port: 4/0; INST/CHAN uses p_i2cafp_ctx Tom_POLLER4 inst 4, dev 2, chain 0, log_id 4, ports/poll 6, num poll 8, present 0, block type = (0x00000032) <TP27:#0x2861d1#>
May 2 10:50:54.419 lda/svr/debugs 0/1/CPU0 t1 laguna[36897]<7180:lda_pwg_get_i2cafp_ctx>: INFO: Bay/Port: 3/0; INST/CHAN uses p_i2cafp_ctx Tom_POLLER3 inst 3, dev 1, chain 0, log_id 3, ports/poll 6, num poll 8, present 0, block type = (0x00000032) <TP27:#0x2861d0#>
May 2 10:50:54.374 lda/svr/debugs 0/1/CPU0 t1 laguna[36897]<7180:lda_pwg_get_i2cafp_ctx>: INFO: Bay/Port: 2/0; INST/CHAN uses p_i2cafp_ctx Tom_POLLER2 inst 2, dev 1, chain 0, log_id 2, ports/poll 6, num poll 8, present 7, block type = (0x00000032) <TP27:#0x2861cf#>
May 2 10:50:54.328 lda/svr/debugs 0/1/CPU0 t1 laguna[36897]<7180:lda_pwg_get_i2cafp_ctx>: INFO: Bay/Port: 1/0; INST/CHAN uses p_i2cafp_ctx Tom_POLLER1 inst 1, dev 1, chain 0, log_id 1, ports/poll 6, num poll 8, present 59, block type = (0x00000032) <TP27:#0x2861ce#>
May 2 10:50:54.260 lda/svr/debugs 0/1/CPU0 t1 laguna[36897]<7180:lda_pwg_get_i2cafp_ctx>: INFO: Bay/Port: 0/0; INST/CHAN uses p_i2cafp_ctx Tom_POLLER0 inst 0, dev 1, chain 0, log_id 0, ports/poll 6, num poll 8, present 63, block type = (0x00000032) <TP27:#0x2861cd#>
May 2 10:50:54.259 lda/svr/info 0/1/CPU0 t1 laguna[36897]<4817:lda_dictionary_opcode_lookup>: INFO: Requesting opcode handler: ldaoptics_get_sensor_status_bulk. opcode = (0x000001c3) <TP25:#0xd7dec#>
May 2 10:50:49.169 lda/svr/info 0/1/CPU0 t11 laguna[36897]<61:lda_irpt_os_interrupt_unmask>: INFO: Inst 206; interrupt mask count matched (0x00000000) <TP26:#0xd7deb#>
May 2 10:50:49.169 lda/svr/info 0/1/CPU0 t11 laguna[36897]<285:lda_api_irpt_hdlr>: INFO: Inst 206; LDA IRPT; code:0x0000007f value:0x00000000 irq:0x000000ce, state:4, enable 0, handle aa7ca2c (0x00000000) <TP26:#0xd7dea#>
May 2 10:50:49.168 lda/svr/debugs 0/1/CPU0 t1 laguna[36897]<7180:lda_pwg_get_i2cafp_ctx>: INFO: Bay/Port: 6/1; INST/CHAN uses p_i2cafp_ctx Tom_POLLER6 inst 6, dev 2, chain 0, log_id 6, ports/poll 6, num poll 8, present 2, block type = (0x00000032) <TP27:#0x2861cc#>
May 2 10:50:49.168 lda/svr/errors 0/1/CPU0 t11 <6:LOC>: LDA FMEA TIMEOUT ERR bus (6) fpga (2) to_addr (0x40ad707c) to_access (0xb4) <TP211:#0x47cf5#>
May 2 10:50:49.167 lda/svr/debugs 0/1/CPU0 t1 laguna[36897]<7180:lda_pwg_get_i2cafp_ctx>: INFO: Bay/Port: 7/0; INST/CHAN uses p_i2cafp_ctx Tom_POLLER7 inst 7, dev 2, chain 0, log_id 7, ports/poll 6, num poll 8, present 0, block type = (0x00000032) <TP27:#0x2861cb#>
May 2 10:50:49.167 lda/svr/debugs 0/1/CPU0 t1 laguna[36897]<7180:lda_pwg_get_i2cafp_ctx>: INFO: Bay/Port: 6/0; INST/CHAN uses p_i2cafp_ctx Tom_POLLER6 inst 6, dev 2, chain 0, log_id 6, ports/poll 6, num poll 8, present 2, block type = (0x00000032) <TP27:#0x2861ca#>
May 2 10:50:49.167 lda/svr/debugs 0/1/CPU0 t1 laguna[36897]<7180:lda_pwg_get_i2cafp_ctx>: INFO: Bay/Port: 5/0; INST/CHAN uses p_i2cafp_ctx Tom_POLLER5 inst 5, dev 2, chain 0, log_id 5, ports/poll 6, num poll 8, present 0, block type = (0x00000032) <TP27:#0x2861c9#>
May 2 10:50:49.167 lda/svr/debugs 0/1/CPU0 t1 laguna[36897]<7180:lda_pwg_get_i2cafp_ctx>: INFO: Bay/Port: 4/0; INST/CHAN uses p_i2cafp_ctx Tom_POLLER4 inst 4, dev 2, chain 0, log_id 4, ports/poll 6, num poll 8, present 0, block type = (0x00000032) <TP27:#0x2861c8#>
May 2 10:50:49.167 lda/svr/debugs 0/1/CPU0 t1 laguna[36897]<7180:lda_pwg_get_i2cafp_ctx>: INFO: Bay/Port: 3/0; INST/CHAN uses p_i2cafp_ctx Tom_POLLER3 inst 3, dev 1, chain 0, log_id 3, ports/poll 6, num poll 8, present 0, block type = (0x00000032) <TP27:#0x2861c7#>
May 2 10:50:49.122 lda/svr/debugs 0/1/CPU0 t1 laguna[36897]<7180:lda_pwg_get_i2cafp_ctx>: INFO: Bay/Port: 2/0; INST/CHAN uses p_i2cafp_ctx Tom_POLLER2 inst 2, dev 1, chain 0, log_id 2, ports/poll 6, num poll 8, present 7, block type = (0x00000032) <TP27:#0x2861c6#>
May 2 10:50:49.076 lda/svr/debugs 0/1/CPU0 t1 laguna[36897]<7180:lda_pwg_get_i2cafp_ctx>: INFO: Bay/Port: 1/0; INST/CHAN uses p_i2cafp_ctx Tom_POLLER1 inst 1, dev 1, chain 0, log_id 1, ports/poll 6, num poll 8, present 59, block type = (0x00000032) <TP27:#0x2861c5#>
May 2 10:50:49.008 lda/svr/debugs 0/1/CPU0 t1 laguna[36897]<7180:lda_pwg_get_i2cafp_ctx>: INFO: Bay/Port: 0/0; INST/CHAN uses p_i2cafp_ctx Tom_POLLER0 inst 0, dev 1, chain 0, log_id 0, ports/poll 6, num poll 8, present 63, block type = (0x00000032) <TP27:#0x2861c4#>
May 2 10:50:49.007 lda/svr/info 0/1/CPU0 t1 laguna[36897]<4817:lda_dictionary_opcode_lookup>: INFO: Requesting opcode handler: ldaoptics_get_sensor_status_bulk. opcode = (0x000001c3) <TP25:#0xd7de9#>
May 2 10:50:43.917 lda/svr/info 0/1/CPU0 t11 laguna[36897]<61:lda_irpt_os_interrupt_unmask>: INFO: Inst 206; interrupt mask count matched (0x00000000) <TP26:#0xd7de8#>
May 2 10:50:43.917 lda/svr/info 0/1/CPU0 t11 laguna[36897]<285:lda_api_irpt_hdlr>: INFO: Inst 206; LDA IRPT; code:0x0000007f value:0x00000000 irq:0x000000ce, state:4, enable 0, handle aa7ca2c (0x00000000) <TP26:#0xd7de7#>
May 2 10:50:43.916 lda/svr/debugs 0/1/CPU0 t1 laguna[36897]<7180:lda_pwg_get_i2cafp_ctx>: INFO: Bay/Port: 6/1; INST/CHAN uses p_i2cafp_ctx Tom_POLLER6 inst 6, dev 2, chain 0, log_id 6, ports/poll 6, num poll 8, present 2, block type = (0x00000032) <TP27:#0x2861c3#>
May 2 10:50:43.916 lda/svr/debugs 0/1/CPU0 t1 laguna[36897]<7180:lda_pwg_get_i2cafp_ctx>: INFO: Bay/Port: 7/0; INST/CHAN uses p_i2cafp_ctx Tom_POLLER7 inst 7, dev 2, chain 0, log_id 7, ports/poll 6, num poll 8, present 0, block type = (0x00000032) <TP27:#0x2861c2#>
May 2 10:50:43.916 lda/svr/errors 0/1/CPU0 t11 <6:LOC>: LDA FMEA TIMEOUT ERR bus (6) fpga (2) to_addr (0x40b2a07c) to_access (0xb4) <TP211:#0x47cf4#>
roinbeltran
Hi tkarnani, already found the port that causing the syslog error. thank you for your support
