NCS 5500 - Netflow egress error when applies to an interface
Hi Community.
I'm trying to deploy netflow on NCS55xx and NCS540 series.
I've created the config due to the manual and some examples.
applying the ingress rule works ok, but when i try to apply the same config on egress it appear this error.
RP/0/RP0/CPU0:rc1-mdz-ncs5500(config-subif)#show configuration failed
Mon Apr 29 13:19:44.420 GMT+3
!! SEMANTIC ERRORS: This configuration was rejected by
!! the system due to semantic errors. The individual
!! errors with each failed configuration command can be
!! found below.
interface HundredGigE0/0/0/30.503
flow ipv4 monitor fmmISP sampler fsmISP egress
!!% 'nfea' detected the 'warning' condition 'Requested operation not supported'
end
RP/0/RP0/CPU0:rc1-mdz-ncs5500(config-subif)#do sh runn int hundredGigE 0/0/0/30.503
Mon Apr 29 13:27:25.937 GMT+3
description Transit-ipv4: {1}
vrf INTERNET
ipv4 address x.x.x.x 255.255.255.252
flow ipv4 monitor fmmISP sampler fsmISP ingress
encapsulation dot1q 503
Here's the config
RP/0/RP0/CPU0:router(config)# flow exporter-map femISP
RP/0/RP0/CPU0:router(config-fem)# destination 172.16.2.111
RP/0/RP0/CPU0:router(config-fem)# source Loopback 0
RP/0/RP0/CPU0:router(config-fem)# transport udp 2055
RP/0/RP0/CPU0:router(config-fem)# dscp 10
RP/0/RP0/CPU0:router(config-fem)# version v9
RP/0/RP0/CPU0:router(config-fem-ver)# template data timeout 600
RP/0/RP0/CPU0:router(config-fem-ver)# options interface-table
RP/0/RP0/CPU0:router(config-fem-ver)# exit
RP/0/RP0/CPU0:router# sampler-map fsmISP
RP/0/RP0/CPU0:router(config-sm)# random 1 out-of 65535
RP/0/RP0/CPU0:router(config)# exit
RP/0/RP0/CPU0:router(config)# flow monitor-map fmmISP
RP/0/RP0/CPU0:router(config-fmm)# record ipv4
RP/0/RP0/CPU0:router(config-fmm)# exporter femISP
RP/0/RP0/CPU0:router(config-fmm)# cache entries 10000
RP/0/RP0/CPU0:router(config-fmm)# cache timeout active 30
RP/0/RP0/CPU0:router(config-fmm)# cache timeout inactive 15
RP/0/RP0/CPU0:router(config-fmm)# exit
is it a problem of the NCS series??
Gabriel
tkarnani
on NCS series only ingress netflow is supported. Egress is not
tkarnani
ok!
Has you any document about tags?
thanks!
