Point to Point L2VPN in IOS XR
darshakpp
Im working out p2p L2vpn between ASR9K and IOS platforms (7600). PE-CE connectivity is using vlan encapsulation at both ends. Default PW type negotiated is ethernet (VC type 5) and VC comes up. But CE to CE communication is not happening. I changed the interworking mode to IP at both ends and it started working.
What is the difference between these PW types. Has anyone come across the same problem? I believe it should work with Ethernet type itself.
Below are the output details before and after changing PW types.
Default PW-type:
Group ASR-G2, XC A-G2, state is up; Interworking none
  AC: GigabitEthernet0/0/0/1.607, state is up
    Type VLAN; Num Ranges: 1
    VLAN ranges: [607, 607]
    MTU 1546; XC ID 0x840004; interworking none
    Statistics:
      packets: received 1045, sent 25782
      bytes: received 123094, sent 1706886
      drops: illegal VLAN 0, illegal length 0
  PW: neighbor 10.20.0.3, PW ID 107, state is up ( established )
    PW class not set, XC ID 0xc0000004
    Encapsulation MPLS, protocol LDP
    Source address 124.7.227.20
    PW type Ethernet, control word disabled, interworking none
    PW backup disable delay 0 sec
    Sequencing not set
    PW Status TLV in use
      MPLS         Local                          Remote
      Label        16022                          45285
      Group ID     0x4000100                      0x0
      Interface    GigabitEthernet0/0/0/1.607     unknown
      MTU          1546                           1546
      Control word disabled                       disabled
     PW type      Ethernet                       Ethernet
      VCCV CV type 0x2                            0x2
                   (LSP ping verification)        (LSP ping verification)
      VCCV CC type 0x6                            0x2
                   (router alert label)           (router alert label)
                   (TTL expiry)
    Incoming Status (PW Status TLV):
      Status code: 0x0 (Up) in Notification message
    Outgoing Status (PW Status TLV):
    MIB cpwVcIndex: 3221225476
    Create time: 19/06/2013 16:23:08 (00:02:30 ago)
    Last time status changed: 19/06/2013 16:25:28 (00:00:10 ago
Interworking IPv4:
Group ASR-G2, XC A-G2, state is up; Interworking IPv4
    MTU 1546; XC ID 0x840004; interworking IPv4
    Statistics:
      packets: received 1045, sent 25780
      bytes: received 123094, sent 1706750
    PW type IP, control word disabled, interworking IPv4
    Sequencing not set
      MPLS         Local                          Remote
      Label        16022                          45280
      MTU          1546                           1546
      PW type      IP                             IP
                   (TTL expiry)
    Create time: 19/06/2013 14:16:02 (02:04:47 ago)
    Last time status changed: 19/06/2013 15:18:07 (01:02:41 ago)
    Statistics:
      packets: received 25780, sent 1045
      bytes: received 1706750, sent 123094
Appreciate your help!
Darshak
Evan Roggenkamp
sorry. necro posting. cisco page loading slow today.
9 Replies 9
Samil Lama
I recommend you to create PW Classes:
7600 Series
Router(config)#
pseudowire-class TEST
Router(config-pw-class)#encapsulation mpls
Router(config-pw-class)#interworking ?
  ethernet  Ethernet interworking
  ip        IP interworking
  vlan      VLAN interworking
Router(config-pw-class)#internetworking ethernet
And call above in the interface
Router(config-if)# xconnect   pw-class TEST
ASR9k Series
RP/0/RSP0/CPU0:router# configure
RP/0/RSP0/CPU0:router(config)# l2vpn
RP/0/RSP0/CPU0:router(config-l2vpn)# pw-class TEST
RP/0/RSP0/CPU0:router(config-l2vpn-pwc)# encapsulation mpls
RP/0/RSP0/CPU0:router(config-l2vpn-pwc-encap-mpls)# transport-mode ethernet
RP/0/RSP0/CPU0:router(config-l2vpn-pwc-encap-mpls)# exit
RP/0/RSP0/CPU0:router(config-l2vpn-pwc-encap)# exit
RP/0/RSP0/CPU0:router(config-l2vpn-pwc)# exit
RP/0/RSP0/CPU0:router(config-l2vpn)# xconnect group TESTGROUP
RP/0/RSP0/CPU0:router(config-l2vpn-xc)# p2p TESTP2P
RP/0/RSP0/CPU0:router(config-l2vpn-xc-p2p)# neighbor pw-id
RP/0/RSP0/CPU0:router(config-l2vpn-xc-p2p-pw)# pw-class TEST
RP/0/RSP0/CPU0:router(config-l2vpn-xc-p2p-pw)# exit
RP/0/RSP0/CPU0:router(config-l2vpn-xc-p2p)# interface TenGigE0/0/0/0.40 //Example
Recommended:
L2VPN on ASR9k
http://www.cisco.com/en/US/docs/routers/asr9000/software/asr9k_r4.1/lxvpn/command/reference/b_lxvpn_cr41asr9k_chapter_010.html#wp3681643325
Regards.
Please don't forget to rate helpful posts.
Hello Samil,
Thanks for the response.
As I mentioned earlier, VC stays up in all the cases. I tried VCtype 5 (Ethernet) and VCtype4 (Ethernet Vlan). I beleive it should be VC type 4, since im using vlan encapsulation on both attachmet circuits. But there is no communication between CE's.
It starts working after configuring Interworking IP on both ends, which removes the layer2 header while sending the payload across the pseudowire.
Darshak
Hello everyone,
I got this solved. I applied " rewrite ingress tag pop..." command on the AC interface. Below is the working configuration.
XR Config:
interface GigabitEthernet0/0/0/1.900609 l2transport
encapsulation dot1q 900 second-dot1q 609
rewrite ingress tag pop 2 symmetric
mtu 1522
l2vpn
pw-class MPLS
  encapsulation mpls
   transport-mode vlan
xconnect group ASR-J2
  p2p ASR-J2
   neighbor 10.10.10.255 pw-id 109
    pw-class MPLS
IOS Config:
interface G0/1.609
xconnect 124.7.227.20 109 encapsulation mpls
What I observed is the difference in the L2 header size calculation. Without the "rewrite" command, XR is calculating L2 header size as 14 bytes without taking the double tag (extra 8 bytes) in consideration. So to get the payload size as 1500 bytes, i applied 1514 bytes on the interface. This matched with the remote end device MTU 1500. But there is no communication between CE.
After applying "rewrite ingress tag pop2 symmetric" command, it does consider the extra bytes as well. I had to set the MTU as 1522 to get the payload size as 1500. Now the CE is able to commmunicate with each other. I tested with IOS and JUNOS on the remote end, the behavior remains the same.
"rewrite ingress tag pop2 symmetric" removes the vlan tags (both outer and inner) while sending the packet across MPLS pseudowire and add both tags back while sending to Attachment circuit.
So here are my questions ,
  1. why XR is not considering vlan tags for L2 header size calculation
  2. How does this behavior change when "rewrite.." command is applied
Appreciate your response.
Darshak
skondala
because IOS pops the tage by default and XR does not.
on XR interface.. you have 2 dot1Q tags so with rewrite POP 2 symmetric
you are removing tags when sending to Core and adding them back when going towards AC side
Reagrds, Satish.
Thanks Satish,
"because IOS pops the tage by default and XR does not. "
So the Packets are carried through the MPLS pseudowire with native ethernet header (14 bytes SA + DA + Ethertype). Vlan Tags will be stripped out.
Darshak
Thats correct...the core wont have any dot1q tags
Reagrds, Satish.
Hello ALL,
by any chance does any one have this configuration working between Junos and Cisco 7600 with the double tag
maritpra
Sorry replied on wrong place.
Evan Roggenkamp
