Bookmark
Subscribe
1298
problem in isis route leaking
fouad.jabri
is there any known issu with ASR903 isis route leaking?
version 3.10.01.S IOS XE
Thanks.
Vinit Jain
Hello Fouad
Could you please share the config and the show version. I have noticed few issues with isis redistribution but need to verify what exactly is being done.
Vinit
--Vinit
Hi Vinit,
show version :
Cisco IOS XE Software, Version 03.10.01.S - Extended Support Release
Cisco IOS Software, ASR903 Software (PPC_LINUX_IOSD-UNIVERSALK9_NPE-M), Version 15.3(3)S1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Fri 25-Oct-13 15:00 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2013 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
ME-MOH-ONE-01 uptime is 2 weeks, 5 days, 14 hours, 51 minutes
Uptime for this control processor is 2 weeks, 5 days, 14 hours, 54 minutes
System returned to ROM by reload
System image file is "bootflash:issu/packages.conf"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: metroaggrservices
License Type: Permanent
Next reload license Level: metroaggrservices
cisco ASR-903 (RSP1) processor with 950897K/6147K bytes of memory.
Processor board ID FOX1740P25G
16 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
3670016K bytes of physical memory.
1328927K bytes of SD flash at bootflash:.
Configuration register is 0x2
config:
router isis xyz
net 49.V.W.X.Y.Z
advertise passive-only
ispf level-1
metric-style wide
no hello padding
log-adjacency-changes
nsf cisco
redistribute isis ip level-1 into level-2 route-map loopback-range1-map
redistribute isis ip level-2 into level-1 route-map loopback-range2-map
passive-interface Loopback0
bfd all-interfaces
mpls ldp sync
Issue: router in the other side can't see leaked routes from l-1 to l-2
What is the output of show ip route on the router on the other side which can't see leaked routes. Can you try the below config and see if its working or not:
int lo0
 isis tag 110
router isis
 net 49.0001.0001.0001.0001.00
 redistribute isis ip level-1 into level-2 route-map match-tag
route-map match-tag permit 10
 match tag 110
--Vinit
quocthaiht6
have the information about the new LSIS?
Macbook Pro
