problem install telnet pakage NSC540 12Z20G
Dhikra Marghli
Level 5
Level 5
  • Hello we have a problem to install a telnet package in NSC540 Cisco . we have a version
  • Cisco IOS XR Software, Version 7.3.2 LNT and
  • we have a error message log when i put this command : install source /harddisk:/files xr-telnet-n540-12z20g-7.3.2v1.0.0-1.x86_64.rpm so the error message is :
  • Once the packaging dependencies have been determined, the install operation may have to reload the system. If you want to control the timing of system reload, you must not continue, but use the 'install package add' command instead, followed by 'install apply'. Continue? [yes/no]:[yes] Continue? [yes/no]:[yes] yes Install source operation 14.1 has started Install operation will continue in the background RP/0/RP0/CPU0:NCS540-JENDOUBA#RP/0/RP0/CPU0:Jun 15 07:58:40.170 UTC: instorch[390]: %INFRA-INSTALL-3-ACTION_FAILED : Packaging operation 14.1.1 failed - Add rejected as there are invalid packages. Packages that could not be found in source '/harddisk:/files': xr-telnet-7.0.1 RP/0/RP0/CPU0:Jun 15 07:58:40.176 UTC: instorch[390]: %INFRA-INSTALL-3-ACTION_FAILED : Install operation (Packaging operation) 14.1.1 failed - Add rejected as there are invalid packages. Packages that could not be found in source '/harddisk:/files': xr-telnet-7.0.1
  • RP/0/RP0/CPU0:NCS540-JENDOUBA#install commit
  • Wed Jun 15 08:04:15.153 UTC Failed to start commit: 'Install' detected the 'warning' condition 'Packaging operation in progress. Cannot accept further requests until complete' RP/0/RP0/CPU0:NCS540-JENDOUBA#RP/0/RP0/CPU0:Jun 15 08:04:33.276 UTC: instorch[390]: %INFRA-INSTALL-3-ACTION_FAILED : Packaging operation 15.1.1 failed - Add rejected as there are invalid packages. Packages that are not user installable: xr-telnet-n540-12z20g-7.3.2v1.0.0-1.x86_64.rpm RP/0/RP0/CPU0:Jun 15 08:04:33.281 UTC: instorch[390]: %INFRA-INSTALL-3-ACTION_FAILED : Install operation (Packaging operation) 15.1.1 failed - Add rejected as there are invalid packages. Packages that are not user installable: xr-telnet-n540-12z20g-7.3.2v1.0.0-1.x86_64.rpm
iw ait from expert NSC answer me and help beacuse it very urgent and customer wait resolve this problem
Thanks to help us this problem
Dhikra Marghli
Level 5
Level 5
Hello
i wait some one help me
thanks
the install procedure is different in XR7
you must create a local repository
check "show install available" once done
then activate the optional packages such as telnet
https://www.cisco.com/c/en/us/td/docs/iosxr/ncs5xx/system-setup/70x/b-system-setup-cg-70x-ncs540/b-system-setup-cg-70x-ncs540_chapter_01001.html
the error you are receiving refers to 7.0.1 package not 732
can you check the package name?
