Segment Routing Tunnel down
dodgerfan78
I have basic scenario R1-R2-R3-R4 in a full mesh
I built a tunnel from R1 to R4 that traverse R2 and R3: R1->R2->R3->R4:
These are loopbacks:
explicit-path name R1234
index 10 next-address strict ipv4 unicast 100.1.1.2
index 20 next-address strict ipv4 unicast 100.1.1.3
index 30 next-address strict ipv4 unicast 100.1.1.4
interface Loopback0
ipv4 address 100.1.1.1 255.255.255.255
interface tunnel-te14
ipv4 unnumbered Loopback0
destination 100.1.1.4
path-selection
segment-routing adjacency protected
path-option 1 explicit name R1234 segment-routing
Each router has a config that looks like this:
router ospf 1
segment-routing mpls
segment-routing forwarding mpls
area 0
mpls traffic-eng
interface Loopback0
prefix-sid index 101 !! (102,103,104 for the others)
interface GigabitEthernet0/0/0/0
network point-to-point
interface GigabitEthernet0/0/0/1
interface GigabitEthernet0/0/0/2
RP/0/0/CPU0:R1#show mpls traffic-eng tunnels
Thu Sep 1 15:12:52.750 UTC
Name: tunnel-te14 Destination: 100.1.1.4 Ifhandle:0x580
Signalled-Name: R1_t14
Status:
Admin: up Oper: down Path: not valid Signalling: Down
path option 1, (Segment-Routing) type explicit R1234
Protected-by PO index: none
Last PCALC Error: Wed Aug 31 15:17:02 2016
Info: No topology
G-PID: 0x0800 (derived from egress interface properties)
Bandwidth Requested: 0 kbps CT0
Creation Time: Wed Aug 31 15:16:33 2016 (23:56:20 ago)
RP/0/0/CPU0:R1#show mpls forwarding
Thu Sep 1 15:13:51.386 UTC
Local Outgoing Prefix Outgoing Next Hop Bytes
Label Label or ID Interface Switched
16102 Pop SR Pfx (idx 102) Gi0/0/0/0 10.1.2.2 520
16103 Pop SR Pfx (idx 103) Gi0/0/0/2 10.1.3.3 520
16104 Pop SR Pfx (idx 104) Gi0/0/0/1 10.1.4.4 51480
Can you tell me what else I am missing?
Bryan
8 Replies 8
Anoop Kalikot Veetil
Hi Bryan,
Can you add " mpls traffic-eng router-id <router-id>" under OSPF and retry ?
Hope you added interfaces under  "mpls traffic-eng". Looks like  TE  topology doesn't have any info, please check  "show mpls traffic-eng   topology  model-type rdm"  output for the prefixes
thanks/Anoop
I do not want to open a new discussion.
Do we have support for segment routing on Trident Line Cards (1st Gen ethernet linecard) on ASR9K?
No, SR is not supported on trident based cards
thanks/Anoop
Ok, thanks for that info.
So we can say that SR is supported on any Typhoon and Tomahawk based line card?
It begs a question why?
I mean SR was around since in 5.2.x, so it’s not the 5.3.4 limit.
Is it then the microcode on Trident that has some limitations with regards to label stack?
adam
adam
it's because of the instruction memory size on Trident NP. There was no space to add more features.
Aah I see, thank you very much.
adam
I am testing a few SR scenarios. We have a large RSVP TE domain and we need to create TE tunnels from SR to RSVP. I was looking into some slides and all I could find is this
This example is working for me (using binding-sid on edge router) but this is more complicated than RSVP TE
Is it really not possible to create a tunnel with dynamic path or explicit path with next address Loopback?
I think that the LSP path is broken between SR and RSVP and that is the reason why we need to use binding sid.
