03-16-2020 05:08 PM
In 32-bit Classic IOS XR, one could easily view the status of craft interface LEDs (e.g. alarm lights on RPs and front panel, etc) by running the "admin show environment leds" command.
However, this command is no longer supported for ASR 9K platform on 64-bit IOS XR. The only command that I know that will show me list of issues now is pretty much 'show pfm location all', which does not show all of the environmental related issues.
Is there a new command in eXR that's equivalent to 'admin show environment leds'?
James
Solved! Go to Solution.
03-16-2020 09:54 PM
Hello James
admin show led
RP/0/RSP1/CPU0:ASR-9904-F-eXR#admin show led Tue Mar 17 04:52:30.620 UTC ============================================================= Location LED Name Mode Color ============================================================= 0/0 0/0-Status LED WORKING GREEN 0/RSP1 0/RSP1-Fail LED WORKING RED 0/RSP1-ACO LED WORKING OFF 0/RSP1-Alarm Minor LED WORKING OFF 0/RSP1-Alarm Major LED WORKING RED 0/RSP1-Alarm Critical LED WORKING OFF 0/RSP1-FC Fault LED WORKING OFF 0/FT0 0/FT0-Status LED WORKING GREEN 0/PT0 0/PT0-PM0-Input OK LED WORKING GREEN 0/PT0-PM0-Output OK LED WORKING GREEN 0/PT0-PM0-Fault LED WORKING OFF 0/PT0-PM1-Input OK LED WORKING GREEN 0/PT0-PM1-Output OK LED WORKING GREEN 0/PT0-PM1-Fault LED WORKING OFF 0/PT0-PM2-Input OK LED WORKING OFF 0/PT0-PM2-Output OK LED WORKING OFF 0/PT0-PM2-Fault LED WORKING OFF 0/PT0-PM3-Input OK LED WORKING OFF 0/PT0-PM3-Output OK LED WORKING OFF 0/PT0-PM3-Fault LED WORKING OFF RP/0/RSP1/CPU0:ASR-9904-F-eXR#
admin show alarms brief
this command will give you more information for the reason of each alarm
Thanks!
03-16-2020 09:54 PM
Hello James
admin show led
Thanks!
03-12-2024 06:44 AM
Might be a dumb question but does this now change w/ IOS XR 7.0+ on NCS' (specifically, that I know of) where the admin command is deprecated?
03-14-2024 10:14 AM
Hello @ChristianH ,
On a XR7 LNT device, show led will work.
Note that admin CLIs have been move to XR on XR7 LNT.
RP/0/RP0/CPU0:XR7LNT#show led
Thu Mar 14 17:04:05.161 UTC
0/FT0 Status/Attention OPERATIONAL GREEN
0/FT1 Status/Attention OPERATIONAL GREEN
0/FT2 Status/Attention OPERATIONAL GREEN
0/FT3 Status/Attention OPERATIONAL GREEN
0/FT4 Status/Attention OPERATIONAL GREEN
0/PM0 Status OPERATIONAL AMBER
0/PM1 Status OPERATIONAL GREEN
0/RP0/CPU0 Attention OPERATIONAL OFF
GPS OPERATIONAL OFF
Status OPERATIONAL BLINKING RED
Sync OPERATIONAL OFF
Kind Regards,
03-14-2024 10:45 AM
Thanks so much! I hadn't realized XR7 removed the Admin LxC entirely so that makes more sense.
