Show loggin in ASR9K
Dear all,
I have this mensage in my logg from the router
" RP/0/RSP0/CPU0:Sep 28 02:56:19.742 : licmgr[317]: %LICENSE-LICMGR-4-PACKAGE_LICENSE_INVALID : Package requesting A9K-LI-LIC license is activated on Rack0 and node node0_RSP0_CPU0 without a valid license/ valid configuration
Can someone explain this message and how to fix that ?
Felizardo Miguel
Mark Malone
That alert means the router has been upgraded and a feature that's in use requires a license for it and is not there
Features that Require Licenses After a Software Image Upgrade
When you upgrade your Cisco IOS XR software image from a release that does not support software entitlement to one that does, a warning message is displayed to the console port for each feature that requires a license. You must acquire either an evaluation license or a permanent license in order to continue using any features that require a license.
During an install activate operation, if the installation fails to acquire a license (through the license manager) for a package that requires licensing then the install operation is allowed but a warning message similar to the following is displayed:
Install operation 10 '(admin) install activate disk0:asr9k-optic-4.0.1.06I'
started by user 'root' via CLI at 09:57:15 pst Tue Aug 10 2010.
RP/0/RSP0/CPU0:Aug 10 09:57:15.058 : instdir[206]:
%INSTALL-INSTMGR-6-INSTALL_OPERATION_STARTED :
Install operation 10 '(admin) install activate disk0:asr9k-optic-4.0.1.06I' started by
user 'root'
/ 1% complete: The operation can still be aborted (ctrl-c for options)RP/0/RSP0/CPU0:
Aug 10 09:57:18.691 : licmgr[237]: %LICENSE-LICMGR-4-PACKAGE_LICENSE_INVALID :
Package A9K-ADV-OPTIC-LIC activated without a valid license/ valid configuration
Warning:  There is no valid license for the following package:
Warning:
Mark Malone
user 'root'
Warning:
Hello Dear,
How can solve this problem to do not show again this mensage?
Hi if you want to stop the message you need to speak with Cisco license team get an evaluation license or buy one option
The other option if its not effecting service you just want to stop seeing the log message in your output , is block it coming from logging using the feature logging discriminator
This will require trying a couple of methods but usually you can block the message by its body type ---- logging discriminator test msg-body drops %LICENSE-LICMGR-4-PACKAGE_LICENSE_INVALID
Associating a Message Discriminator with a Logging Buffer
Perform this task to associate a message discriminator with a specific buffer.
SUMMARY STEPS
1.    enable
2.    configure terminal
3.    logging discriminator discr-name [[facility] [mnemonics] [msg-body] {drops string| includes string}] [severity {drops sev-num | includes sev-num}] [rate-limit msglimit]
4.    logging buffered [discriminator discr-name | xml] [buffer-size] [severity-level]
5.    end
DETAILED STEPS
  Command or Action Purpose
Step 1
enable
Example:
Device> enable
Enables privileged EXEC mode.
  • Enter your password if prompted.
Step 2
configure terminal
Example:
Device# configure terminal
Enters global configuration mode.
Step 3
Example:
Device(config)# logging discriminator pacfltr2
Creates a message discriminator.
Step 4
Example:
Device(config)# logging buffered discriminator pacfltr2 5
Enables logging to a local buffer and specifies a message discriminator.
Step 5
end
Example:
Device(config)# end
Returns the CLI to privileged EXEC mode.
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/esm/configuration/xe-3s/esm-xe-3s-book/reliable-del-filter.html#GUID-6B04B2EA-01C5-4E94-A9C9-1FDDAF5C38D6
