show process cpu history command not in XR-OS (ASR 9K)
jigojar
  how to check the cpu history for last 72 hours in ASR 9K.
Not in the ascii graph style that was available on classic IOS. However, you can monitor the progression of CPU utilisation on the terminal window by running the "top" command. It may come handy to run it with "dumbtty" option, depending on how you prefer to see the output.
hth,
/Aleksandar
5 Replies 5
Aleksandar Vidakovic
This is not available from IOS XR CLI. Most service providers use SNMP (or in very recent releases Telemetry) to graph the CPU utilisation.
A good reference for monitoring CPU via SNMP: https://supportforums.cisco.com/docs/DOC-18746
/Aleksandar
Hi Alex,
Thanks for confirmation. Is their any other way to get the cpu History in the router itself.
hth,
/Aleksandar
Thanks Alex
Back to the stone ages.... They want us to  use GUI's but we don't want to use GUI to keep control. All these fine and great troubleshoot tools are gone but most of use now don't have a clue what is going on the network without these tools. why because it's not real time.
