SNMP drop by AIPC
ReyMartin1
We have a few NCS540 running different OS versions experiencing SNMP query timeout.
If we do snmpwalk, it always timeout at the same spot after  the first few lines:
SNMPv2-MIB::sysDescr.0 = STRING: Cisco IOS XR Software (NCS540L), Version 7.4.2 Copyright (c) 2013-2022 by Cisco Systems, Inc.
SNMPv2-MIB::sysObjectID.0 = OID: SNMPv2-SMI::enterprises.9.1.3143
DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (692600407) 80 days, 3:53:24.07
SNMPv2-MIB::sysContact.0 = STRING:
SNMPv2-MIB::sysName.0 = STRING: xxxxxx
SNMPv2-MIB::sysLocation.0 = STRING: yyyy
SNMPv2-MIB::sysServices.0 = INTEGER: 78
Timeout: No Response from zzzzzz
It seems being dropped by AIPC module (AIPC counter went up by 6 for each request), what is it?
RP/0/RP0/CPU0:xxxxx#sh snmp request drop summary | inc "NMS|y.y.y.y"
Thu Jun 22 16:48:44.040 UTC
NMS Address INQ Encode Duplicate Stack AIPC Overload Timeout Internal Threshold
y.y.y.y 2 649 0 230654 30 0 0 22 0
The bug you mentioned is fixed in your code.
I saw you opened a tac sr but there isnt much data in there, a show snmp trace timeout would help to see which OID is timing out.
Can you also make sure you have this line configured? 'snmp-server ifmib stats cache'
Sam
8 Replies 8
ReyMartin1
Any chance it's this one? CSCve04643
tkarnani
Please check "show snmp trace packet" << check if you are seeing errors
please also check 'show snmp trace slow oid" << check to see if there are slow oid's taking a long time to complete
Thanks for the reply tkarnani,
nothing on 'sh snmp trace slow oid' (lastest entries few days old).
This is from sh snmp trace packet for the failed requests:
Jun 22 16:48:32.758 snmp/packet 0/RP0/CPU0 10803# t8704 ERROR: Internal Dispatch failed for y.y.y.y,15582 (reqID 1238439839) 'Subsystem(8123)' detected the 'resource not available' condition 'Code(7)'
Jun 22 16:48:33.759 snmp/packet 0/RP0/CPU0 7550# t2001 ERROR: Internal Dispatch failed for y.y.y.y,15582 (reqID 1238439839) 'Subsystem(8123)' detected the 'resource not available' condition 'Code(7)'
Jun 22 16:48:34.761 snmp/packet 0/RP0/CPU0 10806# t1504 ERROR: Internal Dispatch failed for y.y.y.y,15582 (reqID 1238439839) 'Subsystem(8123)' detected the 'resource not available' condition 'Code(7)'
Jun 22 16:48:35.762 snmp/packet 0/RP0/CPU0 t8704 ERROR: Internal Dispatch failed for y.y.y.y,15582 (reqID 1238439839) 'Subsystem(8123)' detected the 'resource not available' condition 'Code(7)'
Jun 22 16:48:36.762 snmp/packet 0/RP0/CPU0 14158# t1504 ERROR: Internal Dispatch failed for y.y.y.y,15582 (reqID 1238439839) 'Subsystem(8123)' detected the 'resource not available' condition 'Code(7)'
Jun 22 16:48:37.765 snmp/packet 0/RP0/CPU0 7557# t2001 ERROR: Internal Dispatch failed for y.y.y.y,15582 (reqID 1238439839) 'Subsystem(8123)' detected the 'resource not available' condition 'Code(7)'
Sam
Thanks for the follow up, I've uploaded the command output but from a different device (unfortunately my colleague just restarted the snmp process on the exact device). added the 'snmp-server ifmib stats cache' as well.
Btw any OIDs except the first few lines are all timed out (showing dropped by AIPC) though.
over 90% of the timeouts are due to ifmib, adding that cli i mentioned will help/solve the problem.
https://snmp.cloudapps.cisco.com/Support/SNMP/do/BrowseOID.do?objectInput=1.3.6.1.2.1.2.2.1.2&translate=Translate&submitValue=SUBMIT&submitClicked=true
Sam
Ah got it so the objective is cache the stats to help the system resources, ok I'll monitor it over the next few days. Thanks.
Real time polling of many interfaces all at once is very resource intensive, instead we cache the stats with this cli and read from cache which is much faster, I believe the update period is 30 or 60s. Its one of those knobs we recommend for basically every deployment that uses snmp.
Sam
