Upgrade 0/BPID0/SP Location
j.eduardog
Hello guys,
After downgrading from 5.1.1 to 4.3.4 it shows me that I need to upgrade 0/BPID0/SP Location but I can not find a way to do it, is there any other procedure to do that? here are some outputs when I tried to upgrade the location 0/BPID0/SP
Thanks in advance
RP/0/RSP0/CPU0:MM2MDA-COMEXT-RB01#show hw-module fpd location all
Mon Nov 9 20:28:41.018 UTC
Existing Field Programmable Devices
HW Current SW Upg/
Location Card Type Version Type Subtype Inst Version Dng?
0/RSP0/CPU0 A9K-RSP440-SE 1.0 lc cbc 0 16.115 No
lc fpga3 0 4.09 No
lc fpga1 0 0.10 No
lc fpga2 0 1.06 No
lc rommon 0 0.71 No
0/FT0/SP ASR-9010-FAN-V2 1.0 ft cbc 7 29.11 No
0/FT1/SP ASR-9010-FAN-V2 1.0 ft cbc 8 29.11 No
0/BPID0/SP ASR-9010-BPID2 1.0 N/A cbc 11 7.103 Yes
0/RSP1/CPU0 A9K-RSP440-SE 1.0 lc cbc 0 16.115 No
lc fpga3 0 4.09 No
lc fpga1 0 0.10 No
lc fpga2 0 1.06 No
lc rommon 0 0.71 No
0/3/CPU0 A9K-MOD160-SE 1.0 lc cbc 0 20.117 No
lc fpga4 0 1.05 No
lc fpga2 0 1.04 No
lc rommon 0 2.00 No
0/3/0 A9K-MPA-2X40GE 1.102 spa fpga7 0 1.03 No
0/3/1 A9K-MPA-8X10GE 1.102 spa fpga8 1 1.00 No
0/4/CPU0 A9K-MOD160-SE 1.0 lc cbc 0 20.117 No
lc fpga2 0 1.04 No
lc fpga4 0 1.05 No
lc rommon 0 2.00 No
0/4/0 A9K-MPA-2X40GE 1.102 spa fpga7 0 1.03 No
0/4/1 A9K-MPA-8X10GE 1.102 spa fpga8 1 1.00 No
0/5/CPU0 A9K-MOD160-SE 1.0 lc cbc 0 20.117 No
lc fpga2 0 1.04 No
lc fpga4 0 1.05 No
lc rommon 0 2.00 No
0/5/0 A9K-MPA-20X1GE 1.102 spa fpga3 0 0.08 No
0/5/1 A9K-MPA-2X40GE 1.102 spa fpga7 1 1.03 No
NOTES:
1. One or more FPD needs an upgrade or a downgrade. This can be accomplished
using the "admin> upgrade hw-module fpd <fpd> location <loc>" CLI.
RP/0/RSP0/CPU0:MM2MDA-COMEXT-RB01(admin)#upgrade hw-module fpd all location 0/BPID0/SP
Mon Nov 9 20:30:49.381 UTC
***** UPGRADE WARNING MESSAGE: *****
* This upgrade operation has a maximum timout of 160 minutes. *
* If you are executing the cmd for one specific location and *
* card in that location reloads or goes down for some reason *
* you can press CTRL-C to get back the RP's prompt. *
* If you are executing the cmd for _all_ locations and a node *
* reloads or is down please allow other nodes to finish the *
* upgrade process before pressing CTRL-C. *
% RELOAD REMINDER:
- The upgrade operation of the target module will not interrupt its normal
operation. However, for the changes to take effect, the target module
will need to be manually reloaded after the upgrade operation. This can
be accomplished with the use of "hw-module <target> reload" command.
- If automatic reload operation is desired after the upgrade, please use
the "reload" option at the end of the upgrade command.
- The output of "show hw-module fpd location" command will not display
correct version information after the upgrade if the target module is
not reloaded.
NOTE: Chassis CLI will not be accessible while upgrade is in progress.
Continue? [confirm]
RP/0/RSP0/CPU0:Nov 9 20:30:51.223 : upgrade_fpd_cli[65865]: %PLATFORM-UPGRADE_FPD-6-STATUS : FPD upgrade started.
RP/0/RSP0/CPU0:Nov 9 20:30:51.234 : upgrade_fpd_cli[65865]: %PLATFORM-UPGRADE_FPD-6-STATUS : 0/BPID0/SP does not exist for upgrade
RP/0/RSP0/CPU0:MM2MDA-COMEXT-RB01(admin)#show hw-module fpd location 0/BPID0/SP
Mon Nov 9 20:32:21.694 UTC
HW Current SW Upg/
smilstea
Can you try using location all instead of specifying the location and let me know the result?
Sam
5 Replies 5
smilstea
Sam
Sam, I will try that on monday and will let you know
Sam, I did "upgrade hw-module fpd all location all" and worked fine
thank you
itaiyebali
Whats is this device type fpd location 0/BPID0/SP ? Is it a LC / I/O module or part of RSP or ESP ?
itaiyebali
0/BPID0/SP   ASR-9006-BPID2             1.0   bp   cbc     11      7.103    Yes
? What is the location or this device? which slot ?
