VRF aware NTP issues on IOS-XR 6.1.3
Sumanta Ghosh
Hi Experts
This is the config we have on ASR9K, running IOS-XR. NTP works fine in single VRF. However, on other VRFs, the NTP doesn't respond. We traced packets in NTP debug, no luck. Any special cmd needed, apart from the below? When application sends NTP request to the Loopback199, there is not response. The ASR is synced with a dedicated GPS based NTP device. L3 IP reachability is fine.
RP/0/RSP0/CPU0:Router-1#sh run ntp
Wed Feb 14 08:10:58.078 BST
ntp
 interface Loopback199 vrf om_cn_tenant-1_test
 server vrf nfvi_oam 10.0.92.12 prefer iburst source TenGigE0/0/0/13.4091
 peer vrf om_cn_tenant-1 10.100.4.99 iburst source Loopback99
 update-calendar
RP/0/RSP0/CPU0:Router-1#sh run int lo199
Wed Feb 14 08:11:10.943 BST
 description ***NTP Loopback for Test-Tenant OAM***
 ipv4 address 10.100.5.99 255.255.255.255
Sumanta.
tkarnani
Have we tried with?
ntp
 source Loopback199
end
As per Cisco TAC, the below had to be enabled. Could not find clear example in doc.
ntp
source vrf om_cn_tenant-1 Loopback99
source vrf om_cn_tenant-1_test Loopback199
Sumanta.
So, are these two NTP instances going to see one another as NTP peers/ association
