🎧 Cisco Headset 700 Series: Troubleshooting and FAQ 🎧
davidfit
Follow links to FAQ posts:
  1. Q: What is the Cisco Headsets app, and do I need it? (Cisco Headset 730)
  2. Q: How to find the firmware version on a Cisco Headset 730?
  3. Q: How do I upgrade the firmware on my Cisco Headset 730?
  4. Q: How to find the firmware version and upgrade my USB HD Adapter? (Cisco Headset 730)
  5. Q: How do the controls on the Cisco Headset 730 work?
  6. Q: How to connect a Cisco Headset 730 with an iPhone?
  7. Q: How to connect a Cisco Headset 730 with an Android Phone?
  8. Q: How to connect a Cisco Headset 730 with a Mac computer?
  9. Q: How to connect a Cisco Headset 730 with a Windows computer?
  10. Q: How to connect a Cisco Headset 730 with a DX80/70?
  11. : How to connect a Cisco Headset 730 with a Deskpro?
  12. Q: Which Cisco IP phones is the Cisco Headset 730 compatible with?
  13. Q: How do I connect my Cisco Headset 730 to native bluetooth on my 8845, 8851, 8861 or 8861 Cisco IP Phone?
  14. Q: How many Bluetooth devices can my Cisco Headset 730 connect to simultaneously?
  15. Q: How many devices can my Cisco Headset 730 store in its Bluetooth history?
  16. Q: How far away from the connected Bluetooth device can the Cisco Headset 730 work?
  17. Q: How to set up a Cisco Headset 730 with the Cisco Webex app?
  18. Q: How to set a Cisco Headset 730 headset as the default audio device on Windows 10?
  19. Q: How many types of 700 series headsets are there?
  20. Q: How to adjust how much you hear yourself in your Cisco Headset 730?
  21. Q: How does configuring noise cancellation work?
  22. Q: Are the ear pads on the Cisco Headset 730 replaceable?
  23. Q: Does the USB charging cable also function as an audio cable?
0 Replies 0
