Cisco Webex Python Request Authentication Header
Godwin_S
Frequent Visitor
Frequent Visitor
Hi Friends,
I am trying to explore Cisco Webex REST API with Python and somehow I am stuck in Authentication error. I have successfully created token ID(just mentioned 'xyzxyz' as refernce) , but not sure how to input in GET request. Can someone help please?
Code:
import requests
r=requests.get('https://webexapis.com/v1/[email protected]', headers={'Authentication': 'xyzxyz'}, verify=False)
print(r.content)
Error:
b'{"message":"The request requires a valid access token set in the Authorization request header.","errors":[{"description":"The request requires a valid access token set in the Authorization request header."}],"trackingId":"ROUTER_5F172C02-CCA6-01BB-4D40-AC12DF264D40"}'
Process finished with exit code 0
Anush Kuladeepa
Instead of "Authentication" in your header, use "Authorization" with token.
token = 'Bearer ****'
headers = {
"Authorization" : token,
"Content-Type" : "application/json"
Note: The token **** could be obtained from the https://developer.webex.com/docs/getting-started page after you login.
niharika_krishna
Community Member
You can try this by adding Bearer before inserting the Authentication header ("xyzxyz")
import requests
r=requests.get('https://webexapis.com/v1/[email protected]', headers={'Authentication': 'Bearer xyzxyz'}, verify=False)
print(r.content)
Mike_Brezicky
I hate to not be able to answer the question, but we have a wonderful DevNet community that would be able to dive into the API structure in more depth.
https://community.cisco.com/t5/cloud-collaboration/bd-p/j-disc-dev-cloud-collab
