05-17-2016 05:52 AM
HI,
When we stop REAS service of master server calls are not going via slave REAS, we are able to see master and slave server in REAS management page https://REAS server IP:9990.
when we access the slave server web portal we are not able to see configuration in server.
Is there any way which confirmed that configuration syn happening between master and slave?
Akash
Solved! Go to Solution.
05-17-2016 11:17 AM
Hi Akash,
Is it possible you are experiencing this release noted limitation?
Issue Reference Description
CSCut95043 If the Master REAS node is down then the Finesse Server may not be able to load the Expert Assist Agent Console. In this case the agent will find that the gadget does not load and they will be unable to access Expert Assist functionality.
Rob
05-17-2016 11:17 AM
Hi Akash,
Rob
05-17-2016 08:35 PM
Hi Rob,
I am not even able to make a call from Slave REAS server, when I took REAS admin page access not seen any configuration.
have not checked Gadget is getting loaded or not, will check this also.
Akash
05-31-2016 02:46 PM
Hi Akash,
Any update?
Rob
05-31-2016 09:48 PM
Hi Rob,
We got update from Cisco account team, master and slave to get sync we need to enabled multicast on network, we have master and slave in different network, now it is pending from client side with two options 1. enable multicast 2.move slave in same network of master.
Regarding gadget we are able to render gadgets from both master and slave server(note: we did manual configuration on slave as configuration is not getting sync.)
Akash
06-08-2016 07:52 AM
Hi Akash,
Do these options resolve your issues?
Cheers,
Rich
