02-05-2015 10:38 PM
Is there any plan to expose API to start MeetMe conference from application?
Umesh
02-06-2015 09:11 AM
There are enhancements coming in future releases that will allow it (No details yet). In current versions there is no API to start MeetMe conference.
02-23-2015 10:27 PM
Hi, I know you said no details yet, but do you have any idea of the targeted CUCM version, I am in a desperate need of this functionality.
02-24-2015 04:24 AM
03-03-2015 06:19 AM
I have done it once using UCCX script taking control on an IP Phone through XML.
Caller dials CTI Rte-Pt
UCCX initiate call transfert to meet-me number (get in dtmf from caller)
If transfert successful (meet-me already opened)
If unsuccessful take control on IP Phone with XML Post, press meetme softkey, dial meetme number
Then transfer caller
Finally press endcall softkey (meetme keeps opened since one caller is connected)
This could be adapted to a web service easily
03-03-2015 09:15 PM
Hi Richard,
Thanks for the reply we know workaround using AXL as ur post but a direct API from Cisco will be more robust and stable.
Umesh
03-15-2015 01:10 AM
Hi Umesh,
Could you provide more details about your workaround?
KR
Salim
05-07-2015 10:07 PM
Hi Umesh,
I will be interested to understand how to do it in AXL. Could you share the detail of your workaround?
KR
Salim
02-28-2017 03:58 PM
Hi Guy.
Would you be willing to share your findings? My company is faced with this issue and we're stuck at 8.6.
03-01-2017 01:03 PM
Hi Levi,
Unfortunately there is nothing to share ![]()
Cisco is not interested to bring the MeetMe feature in Jabber. I had this discussion with one my end user no later than last Monday. I really felt powerless when trying to explain that Cisco has decided to not implement the feature to Jabber and is more willing to use the new feature conferencing functionality described by Mohan but only available in CUCM11.5.
The best you could do at this stage is to vote here.
05-04-2016 08:50 PM
Hi Mohan,
Is there any update regarding release of API to start MeetMe conference?
Umesh
05-04-2016 10:04 PM
It seems that there are some enhancements planned to Meet me conference which allows user to set the conference by dialing a number. Application should be able to use connect API to do the same. CUCM 11.5 version with the enhancement should be out in June/July.
01-16-2020 01:07 PM
Hi mpotluri,
Ari
