Call Control
Intro to Ansible
Good Documentation
The Great Selenelion
>> View previously featured conversations <<
Deploying a contact center solution with a customer requirement that on every outbound call made by their agents, they would like the called party to immediately hear a message as soon as they answer. For example, “This is ACME calling. This call may...
ramvelez by Cisco Employee
  • 220 Views
  • 0 replies
We are considering their SupportHub product and have the requirement to link incoming calls to their interface to retrieve caller details and history. I am told that their Contact API - Get endpoint will provide that functionality but we will need to...
Hi,I am working on retreiving call related data using JTAPI. I was able to get few fields using few classes in the JTAPI library. But I was unable to get the information such as Campaign name, Campaign Id, Call Started time, Disconnected Time, Durati...
Using JTAPI, I can currently trigger popups on caller phones via sendData() with API-driven content. Is it possible to instead directly modify the caller's phone display - particularly the called party description - without using popups? What JTAPI m...
melroy by Visitor
  • 584 Views
  • 0 replies
Hello Trying to create a simulated call park solution using CTI Ports for my business,  where we are receiving calls answered by Reception, and then blind transferred to a CTI Port, the call is then answered and held by the CTI Port.   When that CTI ...
Donners by Community Member
  • 1297 Views
  • 2 replies
I am creating a script to play a dynamic prompt i have created a script and all steps seem to get executed but the script fails to play the prompt and when i go to see if the prompt uploaded to the prompt directory its not there.I pulled MIVR logs an...
Varjawand by Visitor
  • 955 Views
  • 1 replies
hey, my application works with 4 cucm nodes on the same cluster with sizing of 10K at the same time and balancing terminals between the nodesthe appuser has 20K devices associated.the application makes getProvider for each cucm node with the same app...
lior look by Level 6
  • 735 Views
  • 0 replies
We are leveraging the Cisco Jabber Web SDK (JavaScript) to enable calling functionality in a kiosk environment.  Video docking is not working as expected on latest chrome browser on windows 11
Hi all, I am currently investigating an issue with a third-party CTI application that terminates the media using the Cisco TSP Media Driver. Intermittently, the customer experiences poor quality audio where a popping sound can be heard over the audio...
dvowell by Level 3
  • 1330 Views
  • 2 replies
