DNAC Assurance lost WLC and Access Point
mmimmi2010
Running WLC 9800-40 with 500 x C9130AXI-E access point. Inventory and compiance status of the WLC is REACHABLE, MANAGED and COMPLIANT. On the Assurance status no WLC and access ponit any more (this issue happend after update to version System 1.5.255 of DNAC).
DNAC is having lots of problem, always running into issue after upgrading the appliances.
System version 1.5.255 is DNA-C 2.1.2.5.
Edit: I'm not sure who marked this is the solution, but this was more for Balaji.Bandi who said that version of DNA did not exist.
11 Replies 11
balaji.bandi
we do not see this version
DNAC is available 1.3 or 2.X
BB
The is for sure an issue there, allways having issues after ugrading the appliance
DNAC for us still usable only as experimental solution, in production it's a nightmare...sorry to say that
I'm facing the same issue.... DNAC is as unstable as Prime...
Any solution to the lost health status? Anyone?
Best regards.
Often the issue is related to certificates.  You can push new ones using the "Update Telemetry Settings" Action in Inventory.  Be sure to select the "Force Configuration Push" Checkbox.
If the telemetry connection is down, "show telemetry internal connection" will show a status of "Connecting".  It might take 5 minutes for it to change to "Active" once the certificate is updated.
If that doesn't fix the problem, please open a TAC Case for further investigation.
Please also make sure your 9800's are upgraded to fix CSCvy30606 so that the certificates can correctly renew themselves after 1 year.
Hi Preston,
many thanks for you input.
Unfortunately the update of the telemetry settings didn't resolve the problem.
And things look good at the wireless controller:
WLC0101#show telemetry internal connection
Telemetry connections
Index Peer Address Port VRF Source Address State
56 172.16.200.10 25103 1 172.16.191.21 Active
WLC0101#show version
Cisco IOS XE Software, Version 17.03.03
@MichlIt was worth a shot.   Please open a TAC case for more thorough troubleshooting.
Dan Rowe
You can use Grafana to monitor the IOSXE-db collector from the System 360 DNAC page. You'll be able to see whether we are receiving telemetry data from the 9800 on the IOSXE-DB collector used by DNA Center for 9800 wireless telemetry.
I checked Grafana and I think DNAC receives telemetry data from WLC:
