Cisco Jabber for Iphone - after taking call - jabber plays ringtone although the call is connected
reindl_mc
Cisco Jabber 9.6.2
iOS 7.1.1
CUCM 9.1.2
Call arrives at iPhone with Cisco Jabber App 9.6.2. Jabber is ringing - after answering the call - Cisco Jabber go on playing the ringtone.
The call is connected with the other party - the other party can also hear you - but you can not hear(only very soft) the caller because of the ringtone is still playing.
Any ideas ?
Thx
7 Replies 7
Jonathan Schulenberg
I have seen this occur once as well. Ensure that detailed logging is turned on and submit the problem report to TAC. I intend to do the same as soon as it repeats, this is likely a new defect in 9.6.2.
@reindl_mc
Could you solve this problem with the TAC?
We have the same issue only on one iPhone with the newest Cisco Jabber Version 10.5.0.
Hi Markus
the problem will be solved with IOS 8.x -  It is an iphone issue !!
kind regards
Does anybody know if there is already a documented bug associated to this issue?
I have the exact same issue CUCM 8.6.2/Presence 8.6.4 and customer is angry and disappointed because of this unexpected behaviour.
iPhones updated to IOS 8.0.2, still have the same issue
Eduardo Cruz
Same problem.
Did you get some solution?
If it is iOS 7 here is the defect:
https://tools.cisco.com/bugsearch/bug/CSCul12803
Symptom:
app's ringtone does not stop after call is answered
Conditions:
Observed intermittently with iOS7
Workaround:
wait until the ringtone stops
