Cisco Unity Connection upgrade path from 11.0.1.20000-2 to 14
MyCommunity
Team
Please advise me on the CUC upgrade path to 14 from the current 11.0.1.20000-2 CUC
Please read the following guides and plan the upgrade accordingly:
  • Unity Connection Install & Upgrade Guide.
  • Release Notes for CUC 14
  • Read Me Guide for CUC 14
Table 1. Upgrade Matrix for Cisco Unity Connection
Upgrade Type
Upgrade Path
Description
Service Update (SU)
Examples of supported paths:
  • 12.x.x/12.x.xSUx1 to 12.x.xSUx2
  • 11.x.x/11.x.xSUx1 to 11.x.xSUx2
  • SU is installed on the inactive partition to which you can switch later on.
  • ISO images are non-bootable images not meant for installation.
Refresh Upgrade (RU)
  • 10.5.2SU10 or earlier to 14
  • 11.5.1SU9 or earlier to 14
Note
  • For 10.5(1) to 14, you must follow an intermediate upgrade path. Example: 10.5(1) to 11.x or later and then 11.x or later to 14.
  • Starting with 14SU2 release, upgrades from release 10.5.2 are blocked so a direct upgrade attempt will fail as an usupported upgrade.
  • If the operating system version of the Unity Connection changes during an upgrade, it is referred to as a Refresh Upgrade (RU).
  • You need the following COP files in same sequence as mentioned below before performing this upgrade:
    • ciscocm.enable-sha512sum-2021-signing-key-v1.0.cop.sgn
    • ciscocm.cuc_upgrade_12_0_v1.3.cop.sgn
  • Select option "Reboot to upgraded partition" on GUI or "Switch to new version if the upgrade is successful" as "Yes" on CLI and proceed with the upgrade.
    Note
    Options "Do not reboot after upgrade" on GUI and "Switch to new version if the upgrade is successful" set as "No" on CLI are not supported.If these options are selected, the system will still reboot and pick the upgraded version.
  • 11.5.1SU10 or later to 14
  • You need the following COP file before performing this upgrade:
      Note
12.0.1SU4 or earlier to 14
      Note
12.0.1SU5 or later to 14
  • No COP file is required for this upgrade path.
    Note
Level 2 (L2)
12.5.1SU3 or earlier to 14
  • If the operating system version of the Unity Connection do not change during an upgrade, it is referred to as an Level 2 (L2) upgrade.
  • The new version is installed on the inactive partition to which you can switch later on.
12.5.1SU4 or later to 14
COP file, for more information, see the Applying COP file from a Network Location
Fix for the same version
  • COP files are installed on the active partition and you cannot uninstall them. Contact Cisco TAC to uninstall COP files.
Response Signature
You should get all the details from the Cisco unity connection upgrade guide. Everything is detailed here including the upgrade path from older versions.
reference: https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/14/install_upgrade/guide/b_14cuciumg/b_14cuciumg_chapter_010.html
From 11.x to 14 is supported, but as @Nithin Eluvathingal go through the documents and please do ask If you have any specific query related to your upgrade?
Apart from the great advice given by @Nithin Eluvathingal and @Shalid Kurunnan Chalil I would recommend you to upgrade to version 15 instead of to 14 as it’s not all that long before it becomes EOL.
Response Signature
