11-26-2019 05:17 AM
Hi all
cucm 12.5su1
cucm-imp 12.5su1
IMP Sync agent seems to be stuck on starting and than stopped in the PUBLISHER node
- i have restarted the server - didn't help
- i have reinstalled the server - didn't help
- found many different Bugs regarding this issue in other versions - but no on mine -tried them ALL - didn't help
Did anyone had this issue in this versions ?
11-26-2019 08:24 AM
12-01-2019 08:22 AM
Thanks for your Quick Reply
Tried It with no Success
Any Ideas ??
12-01-2019 12:47 PM
03-15-2020 10:28 PM
thanks. solved my problem.
03-29-2020 11:26 PM
thanks for this info, fixed my problem. I did not have to wait that long, maybe 5 minutes.
06-08-2020 02:43 AM
i have the same issue, after deleting IMP from CUCM and adding it again the sync agent is not able to run. what did you do ?
