10-09-2013 03:53 AM - edited 03-17-2019 03:37 PM
Hi.
I set up Jabber for connection to Unified Presence server, but when Jabber starts, tries to open go.webex.com/...(I see it on Wireshark and on proxy firewall) Therefore it always displays a window with request of login and password for our proxy server.
Can someone advise how to disable webex connect in Jabber?
10-17-2013 05:19 PM
Are you sure you have installed Jabber and not the webex connect client (which will automatically connect to webex connect cloud services).
In Jabber, before you sign in, you have the choice to choose between server types:
Please remember to rate useful posts, by clicking on the stars below.
10-17-2013 08:09 PM
Its Jabber bug CSCuj14018. Support said this bug will be fixed in 9.2.6
07-21-2014 06:03 AM
Using Wireshark, you can see the IP address of the WebEx connect server that Jabber is trying to connect to. Deny this IP address at the firewall and it will stop behaving in this manner. This is a work around. I have Jabber 9.7 installed and it was doing this to me the other day. I have a ticket in with Cisco to see if there is a different fix.
Please rate helpful posts.
Alex
