how to cutomize LDAP filter in CUCM to match many attributes
NetExprt
Hi all ,
I need to apply LDAP filter in call manager that apply the below in  once customize filter.
1- filter LDAP users whom first name start with "test" or "serv"
2- filter LDAP users whom don't have Email address.
11 Replies 11
you can find many threads in the support forum related to the LDAP custom filter. Please go through the below reference and you may find it easy to construct as per your requirement.
https://www.uccollabing.com/cucm-ldap-filters-explained-find-ldap-attributes-easily/
https://community.cisco.com/t5/collaboration-voice-and-video/ldap-custom-filter-cucm-8-x/ta-p/3125699
Please let us know if you still find it too difficult.
****Please rate the post if you find it usefull.
This is the standard filter that CM will apply even if you don't have defined any custom LDAP filter.
Standard default LDAP filter for users
(&(objectclass=user)(!(objectclass=Computer))(!(UserAccountControl:1.2.840.113556.1.4.803:=2)))
If you would want to add the criteria that you list you would do this.
(&(objectclass=user)(!(objectclass=Computer))(!(UserAccountControl:1.2.840.113556.1.4.803:=2))(email=*)(|(givenName=test*)(givenName=serv*)))
To explain the part some I loaded the filter into a LDAP browser to get a graphical depiction of it.
Response Signature
thanks for your response
I have applied the same and did sync but it didn't filter anything
please advise
Would you mind to rephrase what you want as the result of the filter? In the event that I might have misread what you wrote from the start.
Response Signature
Exactly I need to NOT sync all users that match the below condition (XOR)
1- don't have email ID
2- first name starts with SVC
3- first name starts with health
when I applied the filter which I shared in last message , it did filter many other users and impacted the cisco agents .
Then your filter should be this.
(&(objectclass=user)(!(objectclass=Computer))(!(UserAccountControl:1.2.840.113556.1.4.803:=2))(email=*)(|(!(givenName=SVC*))(!(givenName=health*))))
In the LDAP builder it would look like this.
The difference is that you need to negate the given name part to filter them out. For email that's not needed as you're filtering on that this field has a value, any user with no email address should be filtered out.
Response Signature
To be clear the filter that you have built would include the users that the filter match. If that is not what you intend the filter needs to be modified.
Response Signature
how can we exclude specific OU from sync ?
If the OU is visible in the search path you cannot exclude it as such from the synchronous with a LDAP filter as CM do not support filtering on members of a OU. What you can do is filter on users that belongs to a security group and without to much hassle you should be able to write a PowerShell script that looks for users in the OU and adds them into the group. With that you should effectively have filtered out users in the OU.
Response Signature
You can't filter the OU, instead of syncing from full domain, make multiple LDAP directory and sync each OU. But remember that you can have only 20 LDAP directories.
Response Signature
Remove read rights to that OU on the user you configured for the sync.
java
if this helps, please rate
