Jabber not connecting to deskphone mode
arafmohammed
We have a couple of users where Jabber does not go into phonemode. the phone accounts are set-up correctly, softphone mode is ok. in the logs it shows "UpdateHealth of Deskphone to Unhealthy"
The users are associated to the CTI enabled group as is every other user it works for, PT and CSS we have checked ang again they are correct and are the same for the users it is working for.
Any ideas..deskphone been used is 7942.
any answers or fixes would be appreciated....
Dennis Mink
have you associated the deskphone with the user? in the cucm user->device association.
and have you associated the line on the deskphone with the appropriate user?
Please remember to rate useful posts, by clicking on the stars below.
Fabricio Mora
If the setting below are Ok then please check if the port TCP 2748 is open, otherwise please send us a PRT.
1) The Phone is under the End User control (End User confug page > controlled devices)
2) The End User has the User Group/Role Standard CTI Enabled.
3) The End User is licenses for CUPC.
4) A CTI Profile and a CCMIP Profiles have been assigned to the User on CUPS.
5) If EM is used try without it first.
-Fabricio MS
