02-04-2020 07:11 AM
This just came out yesterday so this is more directed for anyone lurking at Cisco, but how is this supposed to work?
Our UM has been disabled for months because of MS security requirements for resellers that broke the old way so I quickly installed this in my test lab to see if it will fix my issue.
According to all the MS documentation there should be no need to use the old Autodiscover, etc that Unity was using. You just connect to the default outlook.office365.com EWS url and use your oauth info and boom. The whole point is to not have to setup an account with special permissions, etc.
However, the fields for the old account are still there and mandatory and all the test options are going through and failing Autodiscover…
If I look at the Mailbox Sync Logs I don’t see any evidence it’s trying to use Oauth/EWS.
Anyone in the know out there?
04-10-2024 10:46 AM
My customer is planning to migrate from EWS to Microsoft Graph.
We need to know if there is anything from Cisco Unified perspective that we need to be aware of or update.
Is there any Cisco guide for Cisco UCxn to work with and Microsoft Graph
Thank you
04-10-2024 11:06 AM
From what I know CUC version 14 SU3 and onwards uses Graph instead of EWS.
05-22-2024 11:56 AM
Is there any documentation showing 14 SU3 uses graph instead and how to configure?
05-22-2024 12:14 PM
Hi Liz,
This is the response I received from TAC:
The retirement of EWS would be until October 1st, 2026.
As you can confirm in this article from Microsoft:
https://techcommunity.microsoft.com/t5/exchange-team-blog/retirement-of-exchange-web-services-in-exchange-online/ba-p/3924440
But as for today, Unity still doesn’t support Graph, it only supports EWS.
And for the version you have today is 14SU3, you only need the following change:
a. (Applicable to 14SU3 and later releases) Click Application permissions and add full_access_as_app permission in your application. To restrict the permissions, see steps mentioned inTask List for restricting Application Permissions to mailboxes.
But since you have it already because of O365, then there is no change needed from your side regarding this change.
As you can confirm here:
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/14/unified_messaging/guide/b_14cucumgx/b_14cucumgx_chapter_01.html#ID-2370-000005f5
For Graph the Developers from Cisco side are still doing tests to confirm if it would be possible to use it in a future.
But for now as I previously mentioned, is not supported.
05-22-2024 12:21 PM
It is described in this document. Unified Messaging Guide for Cisco Unity Connection Release 14
08-15-2024 08:43 AM
I am running Cisco Unity Connection 15.0.1.11900-14 and I have been strugglling terribly trying to get my Unified Messaging Service to run.
Here is what my configuration looks like:
Here is the result of running the test:
Any clues or assistance appreciated!
08-15-2024 11:12 AM
I found the solution in another thread. It turns out with Outlook 365 Hybrid mode, you have to configure a "Cloud Only User"!
Brian
09-17-2024 03:14 PM
Brian,
Can you please add a link to the other thread or let me know who has to be a "Cloud Only User".
