Speed dial on Cisco Jabber
NetAdminCisco1
Dear All,
Is it possible to configure speed dials so Cisco Jabber, please share the document to configure it.
Secondly when the user change his mobile or reset the jabber account will these speed dials retain in his profile
5 Replies 5
b.winter
There is no option for speed dial buttons available in Jabber.
--- Please rate this post as "Helpful" or accept as a solution, if your question has been answered ---
thanks winter, even its installed on the mobile phone IOS or android device or windows machine/desktop
Cisco Unified Communications Self Care Portal User Guide, Release 10.5(1) - Cisco
this document says we can configure speed dial on cisco jabber
It is more of a short dial then. You dial e.g. "1" and it gets translated to whatever in the background.
So, not the "classic" speed-dial, where you press a button and the phone dials the number associated with that button.
Since Jabber doesn't have this sort of buttons, there are no speed dials.
PTS
Custom Corporate Directory for Cisco Jabber
For more details you can write to info@parsec-tech.com
www.parsec-tech.com
