Phillip Ratliff
Introduction
This document is intended to be a single resource to track which Android phones Cisco Jabber for Android will work on.  While Cisco is only able to officially support the few models that we are able to test on we acknowledge that customers will want to run the application on a wide variety of phones. We will use this document to track the results of testing both by Cisco and by the community.
Note that the latest version of the application is available on the Google Play store.  The 8.6(4) version can still be downloaded as a standalone APK from cisco.com.
This document is open for editing by all users.  Please share your experiences with the community.
Definition of "works"
For the purposes of this document a 'Y' in the "Works" column indicates that the application is able to be provisioned and register with UCM.  If there are specific failures or limitations those should be called out in the Notes for the device.
Cisco Jabber for Android 9.0(1)
ManufacturerModelProviderVersion (android or baseband)Works?Notes
Officially Supported Phones
SamsungGalaxy NexusallAndroid 4.0(4)Y
Galaxy SIIAT&TAndroid 2.3Y
Galaxy SIINTT DocomoAndroid 2.3Y
Galaxy S i9000allAndroid 2.3YGT-I9000
Galaxy AceallAndroid 2.3Y
Galaxy TaballAndroid 2.3YGT-P1000
Unsupported Phones
SamsungGalaxy S3Internationalbaseband I9300XXLFB, XXLH1, XXLG8, XXLG8, DXLF3, XXBLF6YGT-I9300
Galaxy S3InternationalAndroid 4.0.4, baseband ends in XXLF2, XXLEF, BOLE5NGT-I9300
Galaxy S3AT&T
baseband ending in LH1
YSGH-I747
Galaxy S3AT&Tbaseband I747UCLG1NSGH-I747
Galaxy S3AT&Tbaseband I747UCLEMNSGH-I747
Galaxy S3
Verizonbaseband ending in LG7BYSCH-I535
Galaxy S3Verizonbaseband I535VRLF2NSCH-I535
Galaxy S3Sprintbaseband L710VPLG8NSPH-L710
Galaxy S3Three (International)Andriod 4.1.2, baseband I9300NELK2NGT-I9300
Galaxy NoteAT&TAndroid 4.0.4 baseband I717UCLF6YSGH-I717
Galaxy NoteAT&TAndroid 2.3.6 baseband I717UCLA1YSGH-I717
Galaxy Noteunknownbaseband ends in LE6YSGH-I717
Galaxy S2InternationalAndroid 4.0.4 baseband I9100XXLQ8, LQ6YGT-I9100
Galaxy S2Vodafone NLAndroid 4.0.4 baseband I9100BULP8YGT-I9100
Galaxy S2InternationalAndroid 4.0.3 baseband I9100XXLPSNGT-I9100
Galaxy S2InternationalAndroid 4.0.3 baseband I9100BGLP2NGT-I9100
Galaxy S2AT&TAndroid 2.3.6 baseband I777UCKK6YSGH-I777
Galaxy S2T-MobileAndroid 2.3.6 baseband T989UVLDEYSGH-T989
Galaxy S2SprintAndroid 4.0.4 baseband S:D710.10.S.FH13, FL24
NSPH-D710
Galaxy S3OrangeAndroid 4.0.4 baseband I9300BVLE4NGT-I9300
Galaxy S3SprintAndroid 4.0.4; Baseband L710VPLI3NSPH-L710
HTCDesire S
Android 2.3.5 baseband ends in 10.08.04_MY
HPTouchpadWIFI OnlyFlashed with Android 4.0.4Y
LGNexus 4UnlockedAndroid 4.2.2; Baseband M9615A-CEFWMAZM-2.0.1700.48NNexus 4
Cisco Jabber for Android 8.6(4) and earlier
Note that any device that does not work in a later version is expected to not work in prior versions either.  A duplicate non-working phone in both tables is reserved for a phone that has been specifically tested by a user and found to not work.
SamsungGalaxy SIIAT&TAndroid 2.3Y
Galaxy S InternationalallAndroid 2.2.1, 2.3YGT-I9000
Galaxy Tab InternationalallAndroid 2.2.1, 2.3YGT-P1000
Unsupported Phones
Samsung
Galaxy S3
AT&T
baseband I747UCLG1
NSGH-I747
j.faure
i've added Galaxy S3 from Orange provider , not working impossible to register to CUCM
Tiberie Kirijas
I've successfully registered Jabber 9.0.1.2073 on CUCM 8.6 with HTC Desire S with the following specifications:
Android version 2.3.5
Software 2.10.401.8
Kernel 26.35.10
Baseband
20.4801.30.0822u_3822.10.08.04_M
Phillip Ratliff
Thanks!  I added the HTC Desire S with your version info to the table.
Brett Hodgden
I've added the following phone to the 9.0(1) unsupported phones.
tirianwilson
Level 4
Level 4
Here are some more devices for Jabber 9.0(1):
Asus, Transformer Infinity, N/A, Android 4.0.4, N, TF700T
Asus, Transformer Infinity, N/A, Android 4.1 Kernel 3.1.10, N, TF700T
Azpen, A701, N/A, Android 4.0.1 Baseband 1.5 Kenel 3.0.8, Y,
Samsung, Galaxy Note, all (GSM), Android 2.3.6 Baseband ends in XXLA3, N, GT-N7000
Samsung, Galaxy Tab, N/A, Android 4.0.4 Kernel 3.1.10, Y, GT-P7510
HTC, Hero, US Cellular, Android 2.3.4 Baseband 20.31W.30.0815U_1.11.00.0831, Y, USCCADR6285US
alkhalili
I have Google Nexus 4 running android 4.2.2, incoming calls is working but outgoing calls is not due codecs error which appear on the call statistics
cgm
Motorola Atrix (MB860), N/A, Android 2.3.6, N,
All works ... but incoming audio. Strange, DTMF feedback does work. Too bad.
Jiri Solc
Level 5
Level 5
I can confirm Jabber IM 9.0.5.882 and Jabber 9.1.2.3324 are working on intl. Samsung Galaxy S2 GT-9100 with android 4.0.4.
Any update for Nexus 4?
Ryan Rice
Level 4
Level 4
Any updates to this?  Samsung Galaxy S4 came out, jabber installs, won't register.  Android 4.2.2
Jorge Armijo
Level 4
Level 4
Awesome doc, adding to my bookmarks now
gmanzo2000
Add LG L9 with Android 4.1 registered to CUCM 8.6 without any problem for TELCEL Mexico
baalthazaar
Community Member
Installed Jabber 9.1.3 on HTC Thunderbolt running  Android 4.0.4 and got to the point where I clicked verify to connect to the server. My support guy said that it should prompt me for credentials, but it doesn't and now he says that the HTC Thunderbolt is not supported (by referring to this forum). Does anyone know if that is the case or is it just misconfiguration on his part?
iamroot80
Did anyone get Jabber already working on Samsung S4 with CUCM 9.1?
Model number: GT-I9500
Android version: 4.2.2
Baseband version: I9500XXUBMF8
Build number: JDQ29.I9500XXUBMF8
thepoolapk01
I've been working on setting up a master phone list for Cisco Jabber for Android, and it's been a bit challenging to integrate all the contacts seamlessly. The Bitaim integration has brought some unique features to the app, but I'm still fine-tuning the list
Cisco Jabber is a unified communications application that allows you to collaborate with others from your Android device. While Cisco Jabber for Android does not have a built-in feature for managing a master phone list, it can integrate with your corporate directory or address book to access contact information. Here's how you can manage your contacts and create a kind of "master phone list" on Cisco Jabber for Android to netsworths
