Bookmark
Subscribe
4962
After "Queue to Skill Group" call not delivered to agent
I am on a lab SPRAWLER system version 9.0 with IP IVR and System PG configured.
I have a very basic script, initially with Select, to chose an agent. This part works, if the agent is available the call goes straight to the agent.
If agent is not available, then I have "Translation Route to VRU", then "Queue to Skill Group", and then "Run Ext. Script(BasicQ)" then "Wait (5 sec)" which loops back to the "Run Ext. Script(BasicQ)".
The queue works fine, and when no agent is available announces: "Thank you for calling. All our representatives are busy..."
But the problem is, when the agent becomes available, the call does not get put to him.
In the Agent Desktop, I can see that the agent is being reserved though.
The problem is not Calling Search Space. I've checked that already.
Following Router logs are shown when the agent goes into ready state:
15:35:53 rtr      Trace: (33 34 15 : 0 0) DeviceTargetPreCall_V11: CID=(150809,4
3839118), PerID=5000, SGSTID=5003, AGSTID=5004 NetworkCallFlags=0, InvokeID=28,
GREET=
15:35:53 rtr      Trace: (33 34 15 : 0 0) Connect: CID=(150809,43839118), EventS
elect=0, ServiceType=0, RCID=5000, Label(s)=
15:35:53 rtr      Trace: (33 34 15 : 0 0) Deleting Dialog.
15:36:23 rtr      Trace: DEVICE_TARGET_ABORT_IND message received from Periphera
l(5000) CRSCallID(Date 150809 ,ID 43839118), NetworkTarget(-1),MRDomain(1), Agen
tSkillTargetID(-1).
It seems to me that no Labels are returned by Router.
Please let me know if you have any ideas where to look,
George,
20 Replies 20
I have tried that already. Same result.
oabulaban
usually with me when agent is "reserved" but call is not transferred it ends up being some partiion/csp between the cti ports and the phones... can you try sending the call directly to an extension using label? set the label to send the call to the extension and see if it will work
Sent from Cisco Technical Support Android App
That was my first thought as well.
But this is a lab system -> and I have no Partitions and no CSS configured at all.
Every extension on CUCM is on NULL partition, which means everybody can access everything.
Okay, I did not get any closer.
Did you check the usual suspects. Like the Translation Routing. Pguser controlling agent device. Service Control enabled in IP IVR.
G.
Cesar Ortega
Please do the following:
Make you call and notice if agent status goes "Reserved" on CTI Agent Desktop. Now, go to Router Log Viewer on the ICM and post what do you see.
You would see under "Label" the agent extension that has been targeted. You should have the same number under "Device Target".
Cesar
normandt2
Hi guys,
I got the same behavior under version 8.5 but the router try sending the call to the agentID instead of the Label(instrument) associated to the agent desktop.
Here is Router Log windows, and ctisrv log.
Hoping it's will help you to fix this issue.
Normand
Events from December 5, 2013:
09:50:00:194 cg1A-ctisvr Trace: CTIApplication::ProcessTimeNotificationEvent - Time=14:50:00 UTC NewHalfHour=FALSE
09:51:56:444 cg1A-ctisvr Updated 1 ConfigKeys.
09:52:24:765 cg1A-ctisvr Trace: CTIApplication::ProcessClientEventReportRequest - sessionID 2
09:52:24:765 cg1A-ctisvr Trace: CTIApplication::ProcessClientEventReportRequest - CTIOS_NUM_CLIENT:1
09:52:25:918 cg1A-ctisvr Trace: CTIApplication::ProcessClientEventReportRequest - sessionID 2
09:52:25:918 cg1A-ctisvr Trace: CTIApplication::ProcessClientEventReportRequest - CTIOS_NUM_CLIENT:0
09:52:42:145 cg1A-ctisvr Trace: CTIApplication::ProcessClientEventReportRequest - sessionID 2
09:52:42:145 cg1A-ctisvr Trace: CTIApplication::ProcessClientEventReportRequest - CTIOS_NUM_CLIENT:1
09:52:42:149 cg1A-ctisvr Trace: ProcessQueryAgentStateRequest - sessionID 2
09:52:42:149 cg1A-ctisvr Trace: GET_AGENT_STATE_REQ: InvokeID=0x22003018 Periph=5000 MRDomainID= 1 SkillTarID=0 Ext=82868 AGTID=121212 Inst:82868
09:52:42:150 cg1A-ctisvr Trace:
09:52:42:150 cg1A-ctisvr Trace: AGENT_STATE_RESPONSE: InvokeID=0x22003018 ID=121212 Periph=5000 ClientType=17 Online=Y
09:52:42:150 cg1A-ctisvr Trace:                       Ext= Inst= State=LOGOUT Duration=0 Sig=
09:52:42:150 cg1A-ctisvr Trace:                       SkTgtID=5002 SkGrpNo=0xffffffff SkGrpID=-1 NumGroups=2 NumLines=0 CurLine=-1
09:52:42:150 cg1A-ctisvr Trace:                       MRDID=1 NumTasks=0 MaxTaskLimit=0 AgentMode=0 AgentAvailabilityStatus=0
09:52:42:150 cg1A-ctisvr Trace: SkGroup[0]: Number=19155 ID=5000 Pri=0 State=LOGOUT
09:52:42:150 cg1A-ctisvr Trace: SkGroup[1]: Number=3000 ID=5003 Pri=0 State=LOGOUT
09:52:42:156 cg1A-ctisvr Trace: ProcessSetAgentStateRequest - sessionID 2
09:52:42:156 cg1A-ctisvr Trace: *** AddToAssociateAgentList();           ADDED: SessionID=2 AgentID=121212 PeripheralID=5000
09:52:42:156 cg1A-ctisvr Trace: CSTASetAgentState:  InvokeID=0x22003019 Dev=82868 AgentMode=LOG_IN AGID=121212 SG=-1(0xffffffff))
09:52:42:156 cg1A-ctisvr Trace: PrivateData: EventReasonCode=50004 WorkMode=0 NumAdditionalGroups=0 PositionID= SupervisorID= ClientAddress=
09:52:42:160 cg1A-ctisvr Trace: AGENT_EVENT: ID=121212 Periph=5000 Ext=82868 Inst=82868 Sig=
09:52:42:160 cg1A-ctisvr Trace:  SkgState=LOGIN SkgDuration=0 OverallState=NOT_READY OverallDuration=0 Reason=0
09:52:42:160 cg1A-ctisvr Trace:  MRDID=1 NumTasks=0 MaxTaskLimit=1 AgtMode=1 AGTAvailabilityStatus=0 ICMAgtID=5002
09:52:42:160 cg1A-ctisvr Trace:  SkTgtID=5002 SkGrpNo=0x4ad3 SkGrpID=5000 NumLines=0 CurLine=0 ClientStatus=0x0 Direction=0
09:52:42:160 cg1A-ctisvr Trace: SetAgentDevice: Agent(121212) -> Device(82868).
09:52:42:160 cg1A-ctisvr Trace: SetAgentDevice: CSTADevice(82868) -> Agent(121212).
09:52:42:160 cg1A-ctisvr Trace: SET_CLIENT_STATUS_REQ: InvokeID=0x2200301a Periph=5000 Status=0x1 AgentID=121212 Signature:CTIOSServer
09:52:42:160 cg1A-ctisvr Trace:  SkTgtID=5002 SkGrpNo=0xbb8 SkGrpID=5003 NumLines=0 CurLine=0 ClientStatus=0x0 Direction=0
09:52:42:160 cg1A-ctisvr Trace:  SkgState=NOT_READY SkgDuration=0 OverallState=NOT_READY OverallDuration=0 Reason=0
09:52:42:160 cg1A-ctisvr Trace: CSTASetAgentStateConfEvent:  InvokeID=0x22003019
09:52:42:161 cg1A-ctisvr Trace: ProcessQueryAgentStateRequest - sessionID 2
09:52:42:161 cg1A-ctisvr Trace: GET_AGENT_STATE_REQ: InvokeID=0x2200301b Periph=5000 MRDomainID= 1 SkillTarID=0 Ext=82868 AGTID=121212 Inst:82868
09:52:42:162 cg1A-ctisvr Trace: AGENT_EVENT: ID=121212 Periph=5000 Ext=82868 Inst=82868 Sig=CTIOSServer
09:52:42:162 cg1A-ctisvr Trace:  SkgState=UNKNOWN SkgDuration=0 OverallState=NOT_READY OverallDuration=0 Reason=0
09:52:42:162 cg1A-ctisvr Trace:  MRDID=1 NumTasks=0 MaxTaskLimit=1 AgtMode=1 AGTAvailabilityStatus=0 ICMAgtID=5002
09:52:42:162 cg1A-ctisvr Trace:  SkTgtID=5002 SkGrpNo=0xffffffff SkGrpID=-1 NumLines=0 CurLine=0 ClientStatus=0x1 Direction=0
09:52:42:162 cg1A-ctisvr Trace: SET_CLIENT_STATUS_RESP: InvokeID=0x2200301a ResultCode=0(OK)
09:52:42:162 cg1A-ctisvr Trace: AGENT_STATE_RESPONSE: InvokeID=0x2200301b ID=121212 Periph=5000 ClientType=17 Online=Y
09:52:42:162 cg1A-ctisvr Trace:                       Ext=82868 Inst=82868 State=NOT_READY Duration=0 Sig=CTIOSServer
09:52:42:162 cg1A-ctisvr Trace:                       SkTgtID=5002 SkGrpNo=0xffffffff SkGrpID=-1 NumGroups=2 NumLines=0 CurLine=0
09:52:42:162 cg1A-ctisvr Trace:                       MRDID=1 NumTasks=0 MaxTaskLimit=1 AgentMode=1 AgentAvailabilityStatus=0
09:52:42:162 cg1A-ctisvr Trace: SkGroup[0]: Number=19155 ID=5000 Pri=0 State=NOT_READY
09:52:42:162 cg1A-ctisvr Trace: SkGroup[1]: Number=3000 ID=5003 Pri=0 State=NOT_READY
09:52:42:162 cg1A-ctisvr Trace: ProcessAgentDeskSettingsRequest - sessionID 2
09:52:42:162 cg1A-ctisvr Trace: AGENT_DESK_SETTINGS_RESP: InvokeID=0x3025 ResultCode=0 (OK) for peripheral=5000, agent=121212
09:52:42:162 cg1A-ctisvr Trace:  DeskSettingsMask=0x218 WrapupDataIncomingMode=0x3
09:52:42:162 cg1A-ctisvr Trace:  WrapupDataOutgoingMode=0, LogoutNonActivityTime=1800, QualityRecordingRate=-1
09:52:42:162 cg1A-ctisvr Trace:  RingNoAnswerTime=20, SilentMonitorWarningMessage=0, SilentMonitorAudibleIndication=0
09:52:42:162 cg1A-ctisvr Trace:  SupervisorAssistCallMethod=0, EmergencyCallMethod=0
09:52:42:162 cg1A-ctisvr Trace:  AutoRecordOnEmergency=0, RecordingMode=0, WorkModeTimer=10
09:52:42:162 cg1A-ctisvr Trace:  RingNoAnswerDialedNumberID=5000, DefaultDevicePortAddress=
09:52:42:171 cg1A-ctisvr Trace: ProcessAgentGreetingControlRequest - sessionID 2
09:52:42:171 cg1A-ctisvr Trace: CSTAAgentGreetingControlReq:  InvokeID=0x2200301d PeripheralID=5000 AGID=121212 Action=2
09:52:42:172 cg1A-ctisvr Trace:
09:52:42:172 cg1A-ctisvr Trace: CSTAAgentGreetingControlConf:  InvokeID=0x2200301d PeripheralID=5000
09:52:44:517 cg1A-ctisvr Trace: ProcessSnapshotDeviceRequest - sessionID 2
09:52:44:517 cg1A-ctisvr Trace: CSTASnapshotDevice:  InvokeID=0x2200301f SnapshotObject=82868
09:52:44:517 cg1A-ctisvr Trace: CSTASnapshotDeviceConfEvent:  InvokeID=0x2200301f Count=0
09:52:44:517 cg1A-ctisvr Trace: VerifySnapshot(Device 82868): 0 of 0 connections verified.
09:52:44:517 cg1A-ctisvr   CSTA DeviceState: PeripheralID=5000 DeviceID=82868 DeviceType=Device Extension=
09:52:46:960 cg1A-ctisvr Trace: ProcessSetAgentStateRequest - sessionID 2
09:52:46:960 cg1A-ctisvr Trace: CSTASetAgentState:  InvokeID=0x22003022 Dev=82868 AgentMode=READY AGID=121212 SG=-1(0xffffffff))
09:52:46:960 cg1A-ctisvr Trace: PrivateData: EventReasonCode=0 WorkMode=0 NumAdditionalGroups=0 PositionID= SupervisorID= ClientAddress=
09:52:46:961 cg1A-ctisvr Trace: AGENT_EVENT: ID=121212 Periph=5000 Ext=82868 Inst=82868 Sig=CTIOSServer
09:52:46:961 cg1A-ctisvr Trace:  SkgState=AVAILABLE SkgDuration=0 OverallState=AVAILABLE OverallDuration=0 Reason=0
09:52:46:961 cg1A-ctisvr Trace:  MRDID=1 NumTasks=0 MaxTaskLimit=1 AgtMode=1 AGTAvailabilityStatus=1 ICMAgtID=5002
09:52:46:961 cg1A-ctisvr Trace:  SkTgtID=5002 SkGrpNo=0x4ad3 SkGrpID=5000 NumLines=0 CurLine=0 ClientStatus=0x1 Direction=0
09:52:46:961 cg1A-ctisvr Trace:  SkTgtID=5002 SkGrpNo=0xbb8 SkGrpID=5003 NumLines=0 CurLine=0 ClientStatus=0x1 Direction=0
09:52:46:961 cg1A-ctisvr Trace: CSTASetAgentStateConfEvent:  InvokeID=0x22003022
09:53:28:545 cg1A-ctisvr Trace:
09:53:28:545 cg1A-ctisvr Trace: CALL_CREATED: CallID=16781584.69616(d) Dest= Periph=5000 Type=1(ACD_IN) ECCsize=0 Disposition=0(INVALID)
09:53:28:545 cg1A-ctisvr Trace:               CampaignID=-1 QueryRuleID=-1
09:53:28:545 cg1A-ctisvr Trace:               TrunkGroup=-1 DNIS:81707 ANI:69616 CED: Dialed=
09:53:28:545 cg1A-ctisvr Trace:               UserToUser= Wrapup= CustomerPhoneNumber= CustomerAccountNumber=
09:53:28:545 cg1A-ctisvr Trace: PV1= PV2= PV3= PV4= PV5=
09:53:28:545 cg1A-ctisvr Trace: PV6= PV7= PV8= PV9= PV10=
09:53:28:546 cg1A-ctisvr Trace:
09:53:28:546 cg1A-ctisvr Trace: CALL_DATA_UPDATE: CID=16781584.69616(d) Dest= Active=Y Periph=5000 ECCsize=0
09:53:28:546 cg1A-ctisvr Trace:  CallType=1(ACD_IN) CPDisposition=0(INVALID) TrunkGroup=-1
09:53:28:546 cg1A-ctisvr Trace:  RouterCallKey=150818 201 CampaignID=-1 QueryRuleID=-1
09:53:28:546 cg1A-ctisvr Trace:  DNIS:81707 ANI:69616 CED: Dialed=
09:53:28:546 cg1A-ctisvr Trace:  UserToUser= Wrapup=
09:53:28:546 cg1A-ctisvr Trace:  CustPhone#= CustAccount#=
09:53:28:546 cg1A-ctisvr Trace:  PV1= PV2= PV3= PV4= PV5=
09:53:28:546 cg1A-ctisvr Trace:  PV6= PV7= PV8= PV9= PV10=
09:53:28:546 cg1A-ctisvr Trace:  SrcAgentExt=(CS_NULL) DestAgentExt=(CS_NONE)
09:53:28:554 cg1A-ctisvr Trace:
09:53:28:554 cg1A-ctisvr Trace: CSTA_CALL_CLEARED - callID=16781584.(s)  localConnectionInfo(-1)=CS_NONE cause=1015
09:53:28:554 cg1A-ctisvr Trace: ProcessCallClearedEvent -  peripheralID 5000 CallID 16781584
09:53:28:554 cg1A-ctisvr Trace: CALL TERMINATED: CallID=16781584.69616(d) Periph=5000
09:53:38:573 cg1A-ctisvr Trace:
09:53:38:573 cg1A-ctisvr Trace: DEVICE_TARGET_PRE_CALL_IND - Instrument=82868 RouterCallKey=150818 201 NetworkTargetID=5001
09:53:38:573 cg1A-ctisvr Trace: SvSkTargID=5004(3000) SkGroupSkTarID=5003(3000)
09:53:38:573 cg1A-ctisvr Trace: AgSkTargID=5002 ANI=69616 CED=
09:53:38:573 cg1A-ctisvr Trace: Var1= Var2= Var3= Var4= Var5=3
09:53:38:573 cg1A-ctisvr Trace: Var6= Var7= Var8= Var9= Var10=
09:53:38:573 cg1A-ctisvr Trace: CallTypeID=5001 PreCallInvokeID=29
09:53:38:574 cg1A-ctisvr Trace: AGENT_EVENT: ID=121212 SkgState=BUSY_OTHER Periph=5000 Ext=82868 Inst=82868 Sig=CTIOSServer MRDID=1 SkTgtID=5002 SkGrpNo=0x4ad3 SkGrpID=5000 Direction=0
09:53:38:574 cg1A-ctisvr Trace: AGENT_EVENT: ID=121212 Periph=5000 Ext=82868 Inst=82868 Sig=CTIOSServer
09:53:38:574 cg1A-ctisvr Trace:  SkgState=RESERVED SkgDuration=0 OverallState=RESERVED OverallDuration=0 Reason=0
09:53:38:574 cg1A-ctisvr Trace:  MRDID=1 NumTasks=1 MaxTaskLimit=1 AgtMode=1 AGTAvailabilityStatus=0 ICMAgtID=5002
09:53:38:574 cg1A-ctisvr Trace:  SkTgtID=5002 SkGrpNo=0xbb8 SkGrpID=5003 NumLines=0 CurLine=0 ClientStatus=0x1 Direction=0
09:54:08:597 cg1A-ctisvr Trace:
09:54:08:597 cg1A-ctisvr Trace: DEVICE_TARGET_ABORT_IND - Instrument=82868 RouterCallKey=150818 201 NetworkTargetID=5001
09:54:08:597 cg1A-ctisvr Trace: AGENT_EVENT: ID=121212 Periph=5000 Ext=82868 Inst=82868 Sig=CTIOSServer
09:54:08:597 cg1A-ctisvr Trace:  SkgState=AVAILABLE SkgDuration=0 OverallState=AVAILABLE OverallDuration=0 Reason=0
09:54:08:597 cg1A-ctisvr Trace:  MRDID=1 NumTasks=0 MaxTaskLimit=1 AgtMode=1 AGTAvailabilityStatus=1 ICMAgtID=5002
09:54:08:597 cg1A-ctisvr Trace:  SkTgtID=5002 SkGrpNo=0x4ad3 SkGrpID=5000 NumLines=0 CurLine=0 ClientStatus=0x1 Direction=0
09:54:08:597 cg1A-ctisvr Trace:  SkTgtID=5002 SkGrpNo=0xbb8 SkGrpID=5003 NumLines=0 CurLine=0 ClientStatus=0x1 Direction=0
09:55:00:188 cg1A-ctisvr Trace: CTIApplication::ProcessTimeNotificationEvent - Time=14:55:00 UTC NewHalfHour=FALSE
09:55:28:312 cg1A-ctisvr Trace: ProcessSetAgentStateRequest - sessionID 2
09:55:28:312 cg1A-ctisvr Trace: CSTASetAgentState:  InvokeID=0x22003041 Dev=82868 AgentMode=NOT_READY AGID=121212 SG=-1(0xffffffff))
09:55:28:312 cg1A-ctisvr Trace: PrivateData: EventReasonCode=2 WorkMode=0 NumAdditionalGroups=0 PositionID= SupervisorID= ClientAddress=
09:55:28:313 cg1A-ctisvr Trace: AGENT_EVENT: ID=121212 Periph=5000 Ext=82868 Inst=82868 Sig=CTIOSServer
09:55:28:313 cg1A-ctisvr Trace:  SkgState=NOT_READY SkgDuration=0 OverallState=NOT_READY OverallDuration=0 Reason=2
09:55:28:313 cg1A-ctisvr Trace:  MRDID=1 NumTasks=0 MaxTaskLimit=1 AgtMode=1 AGTAvailabilityStatus=0 ICMAgtID=5002
09:55:28:313 cg1A-ctisvr Trace:  SkTgtID=5002 SkGrpNo=0x4ad3 SkGrpID=5000 NumLines=0 CurLine=0 ClientStatus=0x1 Direction=0
09:55:28:313 cg1A-ctisvr Trace:  SkTgtID=5002 SkGrpNo=0xbb8 SkGrpID=5003 NumLines=0 CurLine=0 ClientStatus=0x1 Direction=0
09:55:28:313 cg1A-ctisvr Trace: CSTASetAgentStateConfEvent:  InvokeID=0x22003041
09:55:40:164 cg1A-ctisvr Trace:
09:55:40:164 cg1A-ctisvr Trace: CALL_CREATED: CallID=16781585.69616(d) Dest= Periph=5000 Type=1(ACD_IN) ECCsize=0 Disposition=0(INVALID)
09:55:40:164 cg1A-ctisvr Trace:               CampaignID=-1 QueryRuleID=-1
09:55:40:164 cg1A-ctisvr Trace:               TrunkGroup=-1 DNIS:81707 ANI:69616 CED: Dialed=
09:55:40:164 cg1A-ctisvr Trace:               UserToUser= Wrapup= CustomerPhoneNumber= CustomerAccountNumber=
09:55:40:164 cg1A-ctisvr Trace: PV1= PV2= PV3= PV4= PV5=
09:55:40:164 cg1A-ctisvr Trace: PV6= PV7= PV8= PV9= PV10=
09:55:40:165 cg1A-ctisvr Trace:
09:55:40:165 cg1A-ctisvr Trace: CALL_DATA_UPDATE: CID=16781585.69616(d) Dest= Active=Y Periph=5000 ECCsize=0
09:55:40:165 cg1A-ctisvr Trace:  CallType=1(ACD_IN) CPDisposition=0(INVALID) TrunkGroup=-1
09:55:40:165 cg1A-ctisvr Trace:  RouterCallKey=150818 202 CampaignID=-1 QueryRuleID=-1
09:55:40:165 cg1A-ctisvr Trace:  DNIS:81707 ANI:69616 CED: Dialed=
09:55:40:165 cg1A-ctisvr Trace:  UserToUser= Wrapup=
09:55:40:165 cg1A-ctisvr Trace:  CustPhone#= CustAccount#=
09:55:40:165 cg1A-ctisvr Trace:  PV1= PV2= PV3= PV4= PV5=
09:55:40:165 cg1A-ctisvr Trace:  PV6= PV7= PV8= PV9= PV10=
09:55:40:165 cg1A-ctisvr Trace:  SrcAgentExt=(CS_NULL) DestAgentExt=(CS_NONE)
09:55:40:171 cg1A-ctisvr Trace:
09:55:40:171 cg1A-ctisvr Trace: CSTA_CALL_CLEARED - callID=16781585.(s)  localConnectionInfo(-1)=CS_NONE cause=1015
09:55:40:171 cg1A-ctisvr Trace: ProcessCallClearedEvent -  peripheralID 5000 CallID 16781585
09:55:40:171 cg1A-ctisvr Trace: CALL TERMINATED: CallID=16781585.69616(d) Periph=5000
09:56:30:838 cg1A-ctisvr Updated 1 ConfigKeys.
09:57:08:938 cg1A-ctisvr Updated 1 ConfigKeys.
09:58:57:985 cg1A-ctisvr Updated 1 ConfigKeys.
09:59:45:282 cg1A-ctisvr Updated 1 ConfigKeys.
09:59:52:332 cg1A-ctisvr Updated 1 ConfigKeys.
10:00:00:282 cg1A-ctisvr Trace: CTIApplication::ProcessTimeNotificationEvent - Time=15:00:00 UTC NewHalfHour=TRUE
10:00:00:548 cg1A-ctisvr CTIServer ACTIVE, 1 CTI Client connection(s), 0 call(s) in progress, PG Status: NORMAL
10:00:00:548 cg1A-ctisvr    Period connection(s): 0       Period call(s): 2 (0.00 calls/sec)
10:00:00:548 cg1A-ctisvr    Period EnterpriseCTI traffic: 1156 messages (0.64 msgs/sec)
10:00:00:548 cg1A-ctisvr                                  225156 bytes / 1800 seconds (125.09 bytes/sec)
10:00:00:548 cg1A-ctisvr                                  211 heartbeats (0.12 hb/sec)
10:00:00:548 cg1A-ctisvr                                  0.01ms average queue time/msg
10:00:00:548 cg1A-ctisvr                                  0.04ms average CPU time/msg (0.00% busy)
10:00:13:639 cg1A-ctisvr Trace:
10:00:13:639 cg1A-ctisvr Trace: CALL_CREATED: CallID=16781586.69616(d) Dest= Periph=5000 Type=1(ACD_IN) ECCsize=0 Disposition=0(INVALID)
10:00:13:639 cg1A-ctisvr Trace:               CampaignID=-1 QueryRuleID=-1
10:00:13:639 cg1A-ctisvr Trace:               TrunkGroup=-1 DNIS:81707 ANI:69616 CED: Dialed=
10:00:13:639 cg1A-ctisvr Trace:               UserToUser= Wrapup= CustomerPhoneNumber= CustomerAccountNumber=
10:00:13:639 cg1A-ctisvr Trace: PV1= PV2= PV3= PV4= PV5=
10:00:13:639 cg1A-ctisvr Trace: PV6= PV7= PV8= PV9= PV10=
10:00:13:639 cg1A-ctisvr Trace: CALL_DATA_UPDATE: CID=16781586.69616(d) Dest= Active=Y Periph=5000 ECCsize=0
10:00:13:639 cg1A-ctisvr Trace:  CallType=1(ACD_IN) CPDisposition=0(INVALID) TrunkGroup=-1
10:00:13:639 cg1A-ctisvr Trace:  RouterCallKey=150818 203 CampaignID=-1 QueryRuleID=-1
10:00:13:639 cg1A-ctisvr Trace:  DNIS:81707 ANI:69616 CED: Dialed=
10:00:13:639 cg1A-ctisvr Trace:  CustPhone#= CustAccount#=
10:00:13:639 cg1A-ctisvr Trace:  SrcAgentExt=(CS_NULL) DestAgentExt=(CS_NONE)
10:00:13:646 cg1A-ctisvr Trace:
10:00:13:646 cg1A-ctisvr Trace: CSTA_CALL_CLEARED - callID=16781586.(s)  localConnectionInfo(-1)=CS_NONE cause=1015
10:00:13:646 cg1A-ctisvr Trace: ProcessCallClearedEvent -  peripheralID 5000 CallID 16781586
10:00:13:646 cg1A-ctisvr Trace: CALL TERMINATED: CallID=16781586.69616(d) Periph=5000
10:00:38:148 cg1A-ctisvr Trace: ProcessSetAgentStateRequest - sessionID 2
10:00:38:148 cg1A-ctisvr Trace: CSTASetAgentState:  InvokeID=0x2200307e Dev=82868 AgentMode=READY AGID=121212 SG=-1(0xffffffff))
10:00:38:148 cg1A-ctisvr Trace: PrivateData: EventReasonCode=0 WorkMode=0 NumAdditionalGroups=0 PositionID= SupervisorID= ClientAddress=
10:00:38:149 cg1A-ctisvr Trace: AGENT_EVENT: ID=121212 Periph=5000 Ext=82868 Inst=82868 Sig=CTIOSServer
10:00:38:149 cg1A-ctisvr Trace:  SkgState=AVAILABLE SkgDuration=0 OverallState=AVAILABLE OverallDuration=0 Reason=0
10:00:38:149 cg1A-ctisvr Trace:  MRDID=1 NumTasks=0 MaxTaskLimit=1 AgtMode=1 AGTAvailabilityStatus=1 ICMAgtID=5002
10:00:38:149 cg1A-ctisvr Trace:  SkTgtID=5002 SkGrpNo=0x4ad3 SkGrpID=5000 NumLines=0 CurLine=0 ClientStatus=0x1 Direction=0
10:00:38:149 cg1A-ctisvr Trace:  SkTgtID=5002 SkGrpNo=0xbb8 SkGrpID=5003 NumLines=0 CurLine=0 ClientStatus=0x1 Direction=0
10:00:38:149 cg1A-ctisvr Trace: CSTASetAgentStateConfEvent:  InvokeID=0x2200307e
10:00:38:199 cg1A-ctisvr Trace:
10:00:38:199 cg1A-ctisvr Trace: DEVICE_TARGET_PRE_CALL_IND - Instrument=82868 RouterCallKey=150818 203 NetworkTargetID=5001
10:00:38:199 cg1A-ctisvr Trace: SvSkTargID=5004(3000) SkGroupSkTarID=5003(3000)
10:00:38:199 cg1A-ctisvr Trace: AgSkTargID=5002 ANI=69616 CED=
10:00:38:199 cg1A-ctisvr Trace: Var1= Var2= Var3=LOGIN Var4= Var5=3
10:00:38:199 cg1A-ctisvr Trace: Var6= Var7= Var8= Var9= Var10=
10:00:38:199 cg1A-ctisvr Trace: CallTypeID=5001 PreCallInvokeID=32
10:00:38:200 cg1A-ctisvr Trace: AGENT_EVENT: ID=121212 SkgState=BUSY_OTHER Periph=5000 Ext=82868 Inst=82868 Sig=CTIOSServer MRDID=1 SkTgtID=5002 SkGrpNo=0x4ad3 SkGrpID=5000 Direction=0
10:00:38:200 cg1A-ctisvr Trace: AGENT_EVENT: ID=121212 Periph=5000 Ext=82868 Inst=82868 Sig=CTIOSServer
10:00:38:200 cg1A-ctisvr Trace:  SkgState=RESERVED SkgDuration=0 OverallState=RESERVED OverallDuration=0 Reason=0
10:00:38:200 cg1A-ctisvr Trace:  MRDID=1 NumTasks=1 MaxTaskLimit=1 AgtMode=1 AGTAvailabilityStatus=0 ICMAgtID=5002
10:00:38:200 cg1A-ctisvr Trace:  SkTgtID=5002 SkGrpNo=0xbb8 SkGrpID=5003 NumLines=0 CurLine=0 ClientStatus=0x1 Direction=0
10:01:08:189 cg1A-ctisvr Trace:
10:01:08:189 cg1A-ctisvr Trace: DEVICE_TARGET_ABORT_IND - Instrument=82868 RouterCallKey=150818 203 NetworkTargetID=5001
10:01:08:189 cg1A-ctisvr Trace: AGENT_EVENT: ID=121212 Periph=5000 Ext=82868 Inst=82868 Sig=CTIOSServer
10:01:08:189 cg1A-ctisvr Trace:  SkgState=NOT_READY SkgDuration=0 OverallState=NOT_READY OverallDuration=0 Reason=-15526
10:01:08:189 cg1A-ctisvr Trace:  MRDID=1 NumTasks=0 MaxTaskLimit=1 AgtMode=1 AGTAvailabilityStatus=0 ICMAgtID=5002
10:01:08:189 cg1A-ctisvr Trace:  SkTgtID=5002 SkGrpNo=0x4ad3 SkGrpID=5000 NumLines=0 CurLine=0 ClientStatus=0x1 Direction=0
10:01:08:189 cg1A-ctisvr Trace:  SkTgtID=5002 SkGrpNo=0xbb8 SkGrpID=5003 NumLines=0 CurLine=0 ClientStatus=0x1 Direction=0
10:05:00:176 cg1A-ctisvr Trace: CTIApplication::ProcessTimeNotificationEvent - Time=15:05:00 UTC NewHalfHour=FALSE
10:10:00:169 cg1A-ctisvr Trace: CTIApplication::ProcessTimeNotificationEvent - Time=15:10:00 UTC NewHalfHour=FALSE
10:15:00:162 cg1A-ctisvr Trace: CTIApplication::ProcessTimeNotificationEvent - Time=15:15:00 UTC NewHalfHour=FALSE
10:17:16:853 cg1A-ctisvr Trace: ProcessSetAgentStateRequest - sessionID 2
10:17:16:853 cg1A-ctisvr Trace: *** RemoveFromAssociateAgentList();           REMOVED: SessionID=2 AgentID=121212 PeripheralID=5000
10:17:16:853 cg1A-ctisvr Trace: CSTASetAgentState:  InvokeID=0x2200313d Dev=82868 AgentMode=LOG_OUT AGID=121212 SG=-1(0xffffffff))
10:17:16:853 cg1A-ctisvr Trace: PrivateData: EventReasonCode=1 WorkMode=0 NumAdditionalGroups=0 PositionID= SupervisorID= ClientAddress=
10:17:16:856 cg1A-ctisvr Trace: AGENT_EVENT: ID=121212 Periph=5000 Ext=82868 Inst=82868 Sig=CTIOSServer
10:17:16:856 cg1A-ctisvr Trace:  SkgState=LOGOUT SkgDuration=0 OverallState=NOT_READY OverallDuration=969 Reason=1
10:17:16:856 cg1A-ctisvr Trace:  MRDID=1 NumTasks=0 MaxTaskLimit=1 AgtMode=1 AGTAvailabilityStatus=0 ICMAgtID=5002
10:17:16:856 cg1A-ctisvr Trace:  SkTgtID=5002 SkGrpNo=0x4ad3 SkGrpID=5000 NumLines=0 CurLine=-1 ClientStatus=0x1 Direction=0
10:17:16:856 cg1A-ctisvr Trace: SET_CLIENT_STATUS_REQ: InvokeID=0x2200313e Periph=5000 Status=0x0 AgentID=121212 Signature:
10:17:16:856 cg1A-ctisvr Trace: AGENT_EVENT: ID=121212 Periph=5000 Ext= Inst= Sig=CTIOSServer
10:17:16:856 cg1A-ctisvr Trace:  SkgState=LOGOUT SkgDuration=0 OverallState=LOGOUT OverallDuration=0 Reason=1
10:17:16:856 cg1A-ctisvr Trace:  SkTgtID=5002 SkGrpNo=0xbb8 SkGrpID=5003 NumLines=0 CurLine=-1 ClientStatus=0x1 Direction=0
10:17:16:856 cg1A-ctisvr Trace: CTIUpdateREMask - WARNING: Agent Desk Setting is set to -1.
10:17:16:856 cg1A-ctisvr Trace: ProcessAgentEvent: Agent(121212) cleared from Device(82868).
10:17:16:856 cg1A-ctisvr Trace:  MRDID=1 NumTasks=0 MaxTaskLimit=0 AgtMode=0 AGTAvailabilityStatus=0 ICMAgtID=5002
10:17:16:856 cg1A-ctisvr Trace:  SkTgtID=5002 SkGrpNo=0xffffffff SkGrpID=-1 NumLines=0 CurLine=-1 ClientStatus=0x1 Direction=0
10:17:16:856 cg1A-ctisvr Trace: CSTASetAgentStateConfEvent:  InvokeID=0x2200313d
10:17:16:857 cg1A-ctisvr Trace: AGENT_EVENT: ID=121212 Periph=5000 Ext= Inst= Sig=
10:17:16:857 cg1A-ctisvr Trace:  SkgState=UNKNOWN SkgDuration=0 OverallState=LOGOUT OverallDuration=0 Reason=0
10:17:16:857 cg1A-ctisvr Trace:  MRDID=1 NumTasks=0 MaxTaskLimit=0 AgtMode=0 AGTAvailabilityStatus=0 ICMAgtID=5002
10:17:16:857 cg1A-ctisvr Trace:  SkTgtID=5002 SkGrpNo=0xffffffff SkGrpID=-1 NumLines=0 CurLine=-1 ClientStatus=0x0 Direction=0
10:17:16:857 cg1A-ctisvr Trace: SET_CLIENT_STATUS_RESP: InvokeID=0x2200313e ResultCode=0(OK)
10:17:17:377 cg1A-ctisvr Trace: CTIApplication::ProcessClientEventReportRequest - sessionID 2
10:17:17:377 cg1A-ctisvr Trace: CTIApplication::ProcessClientEventReportRequest - CTIOS_NUM_CLIENT:0
10:20:00:156 cg1A-ctisvr Trace: CTIApplication::ProcessTimeNotificationEvent - Time=15:20:00 UTC NewHalfHour=FALSE
10:25:00:148 cg1A-ctisvr Trace: CTIApplication::ProcessTimeNotificationEvent - Time=15:25:00 UTC NewHalfHour=FALSE
10:30:00:290 cg1A-ctisvr Trace: CTIApplication::ProcessTimeNotificationEvent - Time=15:30:00 UTC NewHalfHour=TRUE
10:30:00:606 cg1A-ctisvr CTIServer ACTIVE, 1 CTI Client connection(s), 0 call(s) in progress, PG Status: NORMAL
10:30:00:606 cg1A-ctisvr    Period connection(s): 0       Period call(s): 1 (0.00 calls/sec)
10:30:00:606 cg1A-ctisvr    Period EnterpriseCTI traffic: 1143 messages (0.64 msgs/sec)
10:30:00:606 cg1A-ctisvr                                  223236 bytes / 1800 seconds (124.02 bytes/sec)
10:30:00:606 cg1A-ctisvr                                  216 heartbeats (0.12 hb/sec)
10:30:00:606 cg1A-ctisvr                                  0.00ms average queue time/msg
10:30:00:606 cg1A-ctisvr                                  0.02ms average CPU time/msg (0.00% busy)
10:35:00:183 cg1A-ctisvr Trace: CTIApplication::ProcessTimeNotificationEvent - Time=15:35:00 UTC NewHalfHour=FALSE
10:40:00:175 cg1A-ctisvr Trace: CTIApplication::ProcessTimeNotificationEvent - Time=15:40:00 UTC NewHalfHour=FALSE
10:45:00:166 cg1A-ctisvr Trace: CTIApplication::ProcessTimeNotificationEvent - Time=15:45:00 UTC NewHalfHour=FALSE
10:50:00:158 cg1A-ctisvr Trace: CTIApplication::ProcessTimeNotificationEvent - Time=15:50:00 UTC NewHalfHour=FALSE
10:55:00:149 cg1A-ctisvr Trace: CTIApplication::ProcessTimeNotificationEvent - Time=15:55:00 UTC NewHalfHour=FALSE
11:00:00:289 cg1A-ctisvr Trace: CTIApplication::ProcessTimeNotificationEvent - Time=16:00:00 UTC NewHalfHour=TRUE
11:00:00:555 cg1A-ctisvr CTIServer ACTIVE, 1 CTI Client connection(s), 0 call(s) in progress, PG Status: NORMAL
11:00:00:555 cg1A-ctisvr    Period connection(s): 0       Period call(s): 0 (0.00 calls/sec)
11:00:00:555 cg1A-ctisvr    Period EnterpriseCTI traffic: 1129 messages (0.63 msgs/sec)
11:00:00:555 cg1A-ctisvr                                  222554 bytes / 1800 seconds (123.64 bytes/sec)
11:00:00:555 cg1A-ctisvr                                  218 heartbeats (0.12 hb/sec)
11:00:00:555 cg1A-ctisvr                                  0.00ms average queue time/msg
11:00:00:555 cg1A-ctisvr                                  0.04ms average CPU time/msg (0.00% busy)
11:05:00:180 cg1A-ctisvr Trace: CTIApplication::ProcessTimeNotificationEvent - Time=16:05:00 UTC NewHalfHour=FALSE
11:10:00:170 cg1A-ctisvr Trace: CTIApplication::ProcessTimeNotificationEvent - Time=16:10:00 UTC NewHalfHour=FALSE
11:15:00:160 cg1A-ctisvr Trace: CTIApplication::ProcessTimeNotificationEvent - Time=16:15:00 UTC NewHalfHour=FALSE
11:20:00:150 cg1A-ctisvr Trace: CTIApplication::ProcessTimeNotificationEvent - Time=16:20:00 UTC NewHalfHour=FALSE
11:25:00:189 cg1A-ctisvr Trace: CTIApplication::ProcessTimeNotificationEvent - Time=16:25:00 UTC NewHalfHour=FALSE
11:30:00:274 cg1A-ctisvr Trace: CTIApplication::ProcessTimeNotificationEvent - Time=16:30:00 UTC NewHalfHour=TRUE
11:30:00:640 cg1A-ctisvr CTIServer ACTIVE, 1 CTI Client connection(s), 0 call(s) in progress, PG Status: NORMAL
11:30:00:640 cg1A-ctisvr    Period connection(s): 0       Period call(s): 0 (0.00 calls/sec)
11:30:00:640 cg1A-ctisvr    Period EnterpriseCTI traffic: 1119 messages (0.62 msgs/sec)
11:30:00:640 cg1A-ctisvr                                  222434 bytes / 1800 seconds (123.57 bytes/sec)
11:30:00:640 cg1A-ctisvr                                  213 heartbeats (0.12 hb/sec)
11:30:00:640 cg1A-ctisvr                                  0.00ms average queue time/msg
11:30:00:640 cg1A-ctisvr                                  0.03ms average CPU time/msg (0.00% busy)
11:35:00:185 cg1A-ctisvr Trace: CTIApplication::ProcessTimeNotificationEvent - Time=16:35:00 UTC NewHalfHour=FALSE
11:40:00:177 cg1A-ctisvr Trace: CTIApplication::ProcessTimeNotificationEvent - Time=16:40:00 UTC NewHalfHour=FALSE
11:45:00:191 cg1A-ctisvr Trace: CTIApplication::ProcessTimeNotificationEvent - Time=16:45:00 UTC NewHalfHour=FALSE
