Automatic recording of all incoming calls in UCCX 5.0
araffill
I would like to know if there is a way to automatically record all incoming calls in UCCX 5.0?
Many Thanks
4 Accepted Solutions
Chris Deren
I would recommand 3rd party solution such as CallRex, NICE, Witness, Colabrio, etc
Chris
I am using Witness,, which supports port spanning on the voice gateway side.. and can set a filter on the numbers,, to record calls as per your choice!!
Nicolas Mansour
Hi there,
You can create a workflow to automatically record all calls. The draw back is that it will save it for 7 days or you will have to create a bulk batch to export them.
We have a customer using this method, and although I dont think Cisco supports it; it does work.
Is there a way of holding the recordings on the server longer than 7 days? I know if they are saved on CSD they will be held for 30 days but our customer would like this behavior for all recordings.
9 Replies 9
Chris Deren
Chris
Hi Chris and Rajesh,
Tx a lot for your helpful responses.
I will talk to my manager regarding purchasing the 3rd party solutions.
Nicolas Mansour
Hi there,
Hi Matt,
By default, the CSD will hold on to the recording for 7 days unless it was extended manually for 30 days (doable only once).
The workaround is to create a script that will automatically export the recordings from UCCX to a specified folder. You can find the steps in the Cisco CAD Service Information under the section "Converting Recordings From *.raw to *.wav".
Enjoy
Hi Nicolas,
Many Thanks for the helpful reply.
I went on a long break from work and missed to reply to your post before my holidays.
My apologies.
Will now start working on the script to automatically record the calls.
Wish you a great year ahead
Cheers.
Is there any document of recording calls using workflows.
Iftikhar
