Bookmark
Subscribe
1335
blocking incoming collect calls
janinegraves
This was asked by one of my students. Can anyone help answer it?
"I  would like to block incoming collect calls in the voice gateway,
but  I'm using R2 digital E1. I need to check the destinations numbers, and  depends of the number, It’ll accept or reject the collect calls.
On  the last PVT of Unified communications in Brazil, some people commented  of to do this block do with TCL scripts with Double-Answer, but I don’t  know much about TCL script."
Thanks, Janine
Andrew Skelly
Level 7
Level 7
I'm not sure how you would block incoming collect calls in the gateway, unless all collect calls showed as from the same originating number.
However most telcos should be able to offer a collect call block feature.
Please rate helpful posts by clicking the thumbs up!
Janine,
if i understand your requirement correctly..you can reject the call using translation rule and mapping to dial-peer.
Reject call on voice router
voice translation-rule 100
rule 1 reject /xxxxxxxxxx/
voice translation-profile reject
translate calling 100
voice-port x/x/x:23
translation-profile incoming reject
First, create a translation rule that will identify the incoming call:
rule 1 reject /2124290000/
rule 2 reject /4089988472/
voice translation-profile call_block_profile
dial-peer voice 111 pots
incoming called-number .
call-block translation-profile incoming call_block_profile
call-block disconnect-cause incoming invalid_number
Then place that translation profile into your inbound dial-peer. It you don't have one defined, create one using the incoming called-number dial-peer command, as so:
The call-block command allows the gateway to give a disconnect message rather than just a fast busy.
