11-03-2010 05:04 AM - edited 03-14-2019 06:49 AM
Hello all,
until yesterday I had a full functioning IPCC Express HA Setup Ver 7.0(1)SR04_Build443 with CAD 6.6.
Since yesterday some of my CAD Clients can´t login. Other CAD Clients can logon successfull.
The error message is: "The request to log into the Cisco Unified CCX application server timed out. Please verify your system is online and try again".
At the moment it seems it has something to do with the Windows user profile or the hole PC. We recognized that sometimes the "defect" ID is working if we log on to the PC with another windows userID. But this can´t be reproduced with a 100% guarantee.
Attached are two log files from the Agent PCs. The Not_OK Agents stops after "Login to telephony server". The OK Agent continues after that with "Login to chat server" and so on.
Any Ideas?
Best regards
Manfred
Solved! Go to Solution.
11-03-2010 07:27 AM
Hello Mandred,
If your CUCM is integraded with AD, this issue could be realated with a know DDTs, this happens because "CAD client software is timing out due to not receiving a response from the UCCX server in the configured and default 10 seconds"
CSCta49259 CAD client timeout value not present in PhoneDev.cfg
Symptom:
Per MIVR logs CAD side is timing out and changes to the server-side properties did not resolve the issue.
Conditions:
UCCX 7.0(1) CAD
Workaround:
on CAD client PC
C:\Program Files\Cisco\Desktop\config, there should be a file
called PhoneDev.cfg.
add ->
[ReqTimeout]
Milliseconds=30000
save then restart the CAD client .
Also See
CSCth74824 - Slow LDAP authentication communications manager
Symptom:
LDAP authentication delayed by 10 seconds
Condition:
CUCM Appliance.
Workaround:
None
Defect opened to make following optimizations:
From the platform API logs, can see CertifiateManager.getCertificate() method being locked.
1)This method probably does not need a lock. Like the enablePort() method, it should probably use a lock duration of 0
2)Also from IMS perspective we can do an optimization. If LDAPS is not configured, don't initialize trust-store.
**Only 1) code changes have been done 2) code changes were done as per communication from dev team.
This issue was disccuesed in the following post a couple of days ago:
https://supportforums.cisco.com/message/3216333#3216333
Many thanks to Pablo and Anuj for the information
Please rate this post if was helpful
Walter Solano
11-03-2010 07:27 AM
Hello Mandred,
Symptom:
Conditions:
UCCX 7.0(1) CAD
Workaround:
on CAD client PC
add ->
[ReqTimeout]
Milliseconds=30000
Also See
Symptom:
Condition:
CUCM Appliance.
Workaround:
None
Walter Solano
11-03-2010 08:28 AM
Hi Walter,
thank you for your fast response.
All of our CAD´s are working now. The add of the missing timer "resolved" our problem.
Best regards
Manfred
11-03-2010 08:47 AM
Is good to hear that everything is working now
02-12-2014 08:16 PM
This also solved my problem for CSCta49259
thanks everyone!
