06-07-2016 11:39 PM - edited 03-15-2019 06:20 AM
Good Day.
We are running UCCX 9.0.2.11001-24 . There is a agent who have a intermittent problem where the phone ring but it will drop within 1 second before agent pickup the call . From the MIVR logs it show transfer interrupt but not able to identify if the issue is on the user end or UCCX end. Please advise if you know if there is away to find out the cause for this .
Call is from 5526 to 4740 (CTI route point) , hit the script and select agent 31209 . Ring 31209 one time and drop (within 1 second) .
Line 489: 17645492: May 26 10:51:50.313 EST %MIVR-SS_TEL-7-UNK:CallID:18266 MediaId:2071379/2 Task:57000090199, ConsultCallObserver RINGING
Line 490: 17645493: May 26 10:51:50.314 EST %MIVR-SS_TEL-7-UNK:Call.transferStarted(31209) JTAPICallContact[id=18266,implId=2071379/2,state=STATE_ANSWERED_IDX,inbound=true,App name=XXX_XX_XXXXXX,task=57000090199,session=41000016453,seq num=0,cn=4740,dn=4740,cgn=5526,ani=null,dnis=null,clid=null,atype=DIRECT,lrd=null,ocn=4740,route=RP[num=4740],OrigProtocolCallRef=00000000001F9B5302F4412D00000000,DestProtocolCallRef=null,TP=12466]
Line 491: 17645494: May 26 10:51:50.314 EST %MIVR-SS_TEL-7-UNK:OrigCall=CallID:18266 MediaId:2071379/2 Task:57000090199, ConsultEvent= (P1-ccx_jtapi_1) 7128349/1 CallCtlConnAlertingEv 31209:P-CC-Admin:1 [#1167809] Cause:100 CallCtlCause:100 CiscoCause:31 FeatReason:12
Line 492: 17645495: May 26 10:51:50.314 EST %MIVR-SS_TEL-7-UNK:CallID:18266 MediaId:2071379/2 Task:57000090199 Got (P1-ccx_jtapi_1) 7128349/1 ConnAlertingEv 31209:P-CC-Admin:1 [#1167808] Cause:100 CallCtlCause:0 CiscoCause:31 FeatReason:12, (P1-ccx_jtapi_1) 7128349/1 CallCtlConnAlertingEv 31209:P-CC-Admin:1 [#1167809] Cause:100 CallCtlCause:100 CiscoCause:31 FeatReason:12, events on the AddressCallObserver.
Line 493: 17645496: May 26 10:51:50.314 EST %MIVR-SS_TEL-7-UNK:CallID:18266 MediaId:2071379/2 Task:57000090199 Got (P1-ccx_jtapi_1) 7128349/1 ConnInProgressEv 31209:P-CC-Admin:1 [#1167806] Cause:100 CallCtlCause:0 CiscoCause:31 FeatReason:12, (P1-ccx_jtapi_1) 7128349/1 CallCtlConnOfferedEv 31209:P-CC-Admin:1 [#1167807] Cause:100 CallCtlCause:-1 CiscoCause:31 FeatReason:12, events on the AddressCallObserver.
Line 790: 17645753: May 26 10:51:51.934 EST %MIVR-SS_TEL-7-UNK:CallID:18266 MediaId:2071379/2 Task:57000090199 gets TermConnDroppedEv, meta code:132, cause code:100
Line 791: 17645754: May 26 10:51:51.934 EST %MIVR-SS_TEL-7-UNK:CallID:18266 MediaId:2071379/2 Task:57000090199, TerminalConnection to Terminal: CTI_12466 is DROPPED, 2071379/2
Line 793: 17645756: May 26 10:51:51.934 EST %MIVR-SS_TEL-7-UNK:Call.abandoned() JTAPICallContact[id=18266,implId=2071379/2,state=STATE_ABANDONED_IDX,inbound=true,App name=XXX_XX_XXXXXX,task=57000090199,session=41000016453,seq num=0,cn=4740,dn=4740,cgn=5526,ani=null,dnis=null,clid=null,atype=DIRECT,lrd=null,ocn=4740,route=RP[num=4740],OrigProtocolCallRef=00000000001F9B5302F4412D00000000,DestProtocolCallRef=null,TP=12466]
Line 794: 17645757: May 26 10:51:51.936 EST %MIVR-SS_TEL-7-UNK:CallID:18266 MediaId:2071379/2 Task:57000090199, transfer interrupted, com.cisco.app.impl.ContactInactiveInterruption: Contact id: 18266, Contact terminated remotely
Line 795: 17645758: May 26 10:51:51.936 EST %MIVR-SS_TEL-7-UNK:OrigCall=CallID:18266 MediaId:2071379/2 Task:57000090199, ConsultEvent= (P1-ccx_jtapi_1) 7128349/1 CallObservationEndedEv [#1167874] Cause:100 CallCtlCause:0 CiscoCause:0 FeatReason:12
Line 796: 17645759: May 26 10:51:51.936 EST %MIVR-SS_TEL-7-UNK:CallID:18266 MediaId:2071379/2 Task:57000090199, ConsultCallObserver():Received msg from original call Interrupted
Line 797: 17645760: May 26 10:51:51.940 EST %MIVR-SS_TEL-7-UNK:CallID:18266 MediaId:2071379/2 Task:57000090199, released TP[type=Cisco CTI Port,id=24,implId=12466,active=false,state=IDLE] from 4740, and releasing udpPort 28218
Line 798: 17645761: May 26 10:51:51.940 EST %MIVR-SS_TEL-7-UNK:CallID:18266 MediaId:2071379/2 Task:57000090199 com.cisco.jtapi.TermObservationEndedEvImpl received
Line 6880: 17651648: May 26 10:51:56.863 EST %MIVR-SS_RM-7-UNK:Task: 57000090199 canceled setting ResourceUnAvailableInterruption
Line 6924: 17651692: May 26 10:51:56.937 EST %MIVR-LIB_EVENT-5-TOO_LONG_IN_QUEUE:Event queue time exceeded: Event=com.cisco.call.CallEvent[CALL_DISCONNECTED,state=CALL_DISCONNECTED,isRemote=true,task=AppTask[id=0xd45785a57,time=1464223901511,state=ABORTED,exception=com.cisco.contact.ContactInactiveException: Contact id: 18266, Channel id: 24, Contact is in Terminated/Connected state,active=false,aborting=com.cisco.contact.ContactInactiveException: Contact id: 18266, Channel id: 24, Contact is in Terminated/Connected state,app=App[name=XXX_XX_XXXXXX,type=Cisco Script Application,id=64,desc=XXX_XX_XXXXXXS,enabled=true,max=60,valid=true,cfg=[ApplicationConfig[schema=ApplicationConfig,time=2015-07-15 14:41:31.0,recordId=186,desc=XXX_XX_XXXXXXS,name=XXX_XX_XXXXXX,type=Cisco Script Application,id=64,enabled=true,sessions=60,script=SCRIPT[XXXXXX.aef],defaultScript=,vars=[],defaultVars=null]]],trigger=ContactApplicationTrigger[time=1464223901511,locale=en_AU,cfg=JTAPITriggerConfig[schema=ApplicationTr...
Thanks.
Best regards,
kelvin
06-08-2016 12:12 AM
CUCM CM and CTI traces would be the next steps.
06-08-2016 06:13 PM
[toc:faq]
Not much in the call logs show .
2016/05/26 10:51:50.158|CC|SETUP|49561913|49561914|12466|31209|31209
2016/05/26 10:51:50.162|CC|OFFERED|49561913|49561914|12466|31209|31209|CTI_12466|SEPD824BD26EB39
2016/05/26 10:51:50.162|SIPL|49561914|TCP|OUT|172.16.29.50|5060|SEPD824BD26EB39|192.168.159.18|51295|2,100,13,1.12869168^*^*|57392202|68edc80-746148a6-24d7ff-321d10ac@172.16.29.50|INVITE
2016/05/26 10:51:50.196|SIPT|49561898|TCP|IN|172.16.29.50|5060|XXX-XXX-XXX-XX_TRUNK|172.16.30.53|5060|2,100,13,62.4882023^172.16.30.53^*|57392203|1319200-7461489d-55e00d-351e10ac@172.16.30.53|100 Trying
2016/05/26 10:51:50.214|SIPT|49561898|TCP|IN|172.16.29.50|5060|XXX-XXX-XXX-XX_TRUNK|172.16.30.53|5060|2,100,13,62.4882024^172.16.30.53^*|57392204|1319200-7461489d-55e00d-351e10ac@172.16.30.53|200 OK
2016/05/26 10:51:50.217|SIPL|49561914|TCP|IN|172.16.29.50|5060|SEPD824BD26EB39|192.168.159.18|51295|2,100,13,774447.339^192.168.159.18^*|57392205|68edc80-746148a6-24d7ff-321d10ac@172.16.29.50|100 Trying
2016/05/26 10:51:50.223|SIPT|49561898|TCP|OUT|172.16.29.50|5060|XXX-XXX-XXX-XX_TRUNK|172.16.30.53|5060|2,100,13,1.12869169^*^*|57392206|1319200-7461489d-55e00d-351e10ac@172.16.30.53|ACK
2016/05/26 10:51:50.303|SIPL|49561914|TCP|IN|172.16.29.50|5060|SEPD824BD26EB39|192.168.159.18|51295|2,100,13,774447.340^192.168.159.18^*|57392207|68edc80-746148a6-24d7ff-321d10ac@172.16.29.50|180 Ringing
2016/05/26 10:51:50.729|CC|SPLIT|49561794|49561818
2016/05/26 10:51:50.735|CC|SPLIT|49561910|49561911
2016/05/26 10:51:50.737|CC|JOIN|49561794|49561911
2016/05/26 10:51:50.740|CC|RELEASE|49561818|0|0
2016/05/26 10:51:50.740|CC|RELEASE|49561910|0|0
2016/05/26 10:51:51.925|SIPT|49561898|TCP|IN|172.16.29.50|5060|XXX-XXX-XXX-XX_TRUNK|172.16.30.53|36983|2,100,13,38.2883985^172.16.30.53^*|57392211|1319200-7461489d-55e00d-351e10ac@172.16.30.53|BYE
2016/05/26 10:51:51.929|CC|RELEASE|49561898|49561901|16
2016/05/26 10:51:51.931|SIPT|49561898|TCP|OUT|172.16.29.50|5060|XXX-XXX-XXX-XX_TRUNK|172.16.30.53|36983|2,100,13,38.2883985^172.16.30.53^*|57392212|1319200-7461489d-55e00d-351e10ac@172.16.30.53|200 OK
2016/05/26 10:51:51.931|SIPT|49561898|TCP|OUT|172.16.29.50|5060|XXX-XXX-XXX-XX_TRUNK|172.16.30.53|5060|2,100,13,38.2883985^172.16.30.53^*|57392213|1319200-7461489d-55e00d-351e10ac@172.16.30.53|SUBSCRIBE
2016/05/26 10:51:51.932|SIPT|49561898|TCP|IN|172.16.29.50|5060|XXX-XXX-XXX-XX_TRUNK|172.16.30.53|36983|2,100,13,38.2883986^172.16.30.53^*|57392214|1319200-7461489d-55e00d-351e10ac@172.16.30.53|NOTIFY
2016/05/26 10:51:51.933|SIPT|49561898|TCP|OUT|172.16.29.50|5060|XXX-XXX-XXX-XX_TRUNK|172.16.30.53|36983|2,100,13,38.2883986^172.16.30.53^*|57392216|1319200-7461489d-55e00d-351e10ac@172.16.30.53|200 OK
2016/05/26 10:51:51.933|SIPT|49561898|TCP|IN|172.16.29.50|5060|XXX-XXX-XXX-XX_TRUNK|172.16.30.53|5060|2,100,13,62.4882025^172.16.30.53^*|57392215|1319200-7461489d-55e00d-351e10ac@172.16.30.53|200 OK
2016/05/26 10:51:51.933|SIPT|49561898|TCP|IN|172.16.29.50|5060|XXX-XXX-XXX-XX_TRUNK|172.16.30.53|36983|2,100,13,38.2883987^172.16.30.53^*|57392217|1319200-7461489d-55e00d-351e10ac@172.16.30.53|NOTIFY
2016/05/26 10:51:51.934|SIPT|49561898|TCP|OUT|172.16.29.50|5060|XXX-XXX-XXX-XX_TRUNK|172.16.30.53|36983|2,100,13,38.2883987^172.16.30.53^*|57392218|1319200-7461489d-55e00d-351e10ac@172.16.30.53|481 Subscription does not exist
2016/05/26 10:51:51.935|SIPL|49561914|TCP|OUT|172.16.29.50|5060|SEPD824BD26EB39|192.168.159.18|51295|2,200,13,70.67535^172.16.30.57^CTI_12466|57392219|68edc80-746148a6-24d7ff-321d10ac@172.16.29.50|CANCEL
2016/05/26 10:51:51.985|SIPL|49561914|TCP|IN|172.16.29.50|5060|SEPD824BD26EB39|192.168.159.18|51295|2,100,13,774447.341^192.168.159.18^*|57392220|68edc80-746148a6-24d7ff-321d10ac@172.16.29.50|200 OK
2016/05/26 10:51:51.987|CC|RELEASE|49561913|49561914|16
2016/05/26 10:51:52.032|SIPL|49561914|TCP|IN|172.16.29.50|5060|SEPD824BD26EB39|192.168.159.18|51295|2,100,13,774447.342^192.168.159.18^*|57392221|68edc80-746148a6-24d7ff-321d10ac@172.16.29.50|487 Request Cancelled
2016/05/26 10:51:52.032|SIPL|49561914|TCP|OUT|172.16.29.50|5060|SEPD824BD26EB39|192.168.159.18|51295|2,100,13,774447.342^192.168.159.18^*|57392222|68edc80-746148a6-24d7ff-321d10ac@172.16.29.50|ACK
06-08-2016 06:32 PM
HI Kelvin,
It doesn't look you have tracing set to detailed level,please enable detailed traces level on CUCM .
06-08-2016 07:01 PM
Thanks Deepak,
We don't have the transcoder in the DP . Only the Software MTP (callmanager) in it . I going to have user to directly call the agent and verify have any issue.
06-08-2016 04:31 AM
Can you please make sure this agent does not have any unsupported configuration such as Idivert key, call forwarding etc.
Deepak
06-08-2016 06:28 PM
Hi Deepak,
Do you mean if the phone have softkey of IDivert or call forwarding ? Or you are referring to if the agent turn on the forward during the time it have the drop call ?
07-16-2020 12:15 PM
Hi, I am facing the same issue. Were you able to figure out what was causing this issue? Thanks
06-09-2016 03:50 AM
Hello Kelvin,
From above logs , the call seems to be disconnected from the source 5526 ..
not much info , does this issue happen with same agent 31209 always ? .. also , does it happen from specific sources ? .. ( internal , external .. )
Thanks A lot,
Ahmed Salah
