06-16-2022 04:53 AM
Hi ,
in the IVR flow , there is Number element (number.MBasicNumber) where phone number is entered by a user. If user enters 012345 , in the menu it is received as 12345 which means starting zero is getting truncated.
Earlier same CVP application was accepting dtmf as 012345 but now its 23456.
In the last few months , we have upgraded to VVB to 12.5 .
Any idea, what can be the reason ?
06-16-2022 08:29 AM
Can you show a picture of that node and the settings from Call Studio (the one that works and the one that doesn't). It would seem strange for it to be truncating a number, it isn't like you're using odd characters that can cause problems like # or *.
Also, what does the log show, can you paste the activity log as well?
06-21-2022 05:43 AM
Hi Team,
When I entered “0123456789” in the dtmf , this element only captured “123456789”.
However few months back , it was capturing complete number starting with zero.
Only change I remembered is VVB 12.5 upgrade.
Does this depends on telecom operator or VVB ?
06-22-2022 05:57 AM
If you haven't done it yet, I would start by confirming exactly what is sent back from the VB to the CVP app. Either turn on the VoiceXML debug logger for your studio app or use Wireshark on the CVP server.
06-23-2022 06:23 PM
Also, for hahas do you see any difference if you set the input method to be DTMF only?
06-23-2022 10:39 PM
No difference if changed Number element for dtmf input.
VVB is truncating the "01234" to "1234".
Any setting on VVB 12.5 to send the complete number without truncating the leading zero ?
06-24-2022 05:03 AM
Hmm, this must be a bug. Do you see the DTMF being recognized in your gateway? Is it only a leading 0 that is being missed or any other DTMF?
david
06-25-2022 05:58 AM
Is it always only if first digit is a 0?
If you enter in 1230, does it always work?
Also, what gateway adapter are you using (i.e. what happens if you stick with the DTMF only thought and try something like VXML 2.1 with Cisco DTMF?
