Calls peresnted vs calls handled vs RNA
Shadyvegas
I don't have rna (rings no answer) in my report so what should do i do?
Please provide the system you are working in (including version) and the report you are trying to generate.
Please also give a little more detail on your issue and what you have tried already.
Maren
Is it uccx, pcce or Wxcc?
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Thomas G. J.
You should make sure which report you are using!
To find the RNA column, use the Historical Report > Inbound > CSQ Agent Summary Report.
