CAXL Connection with Username
Badar Ali
I am able to create an XMPP connection via CAXL (jabberwerx) with agent id, but when I use a username (loginName) it doesn't make a connection and returns a not-authorized error.
I have checked Strophe on the other hand, allows to make a connection with both i.e agentId and username.
Is there a way to make a connection by using username in CAXL?
Thank you.
dekwan
Since your labels are Finesse and UCCE CTI Protocol, I'm assuming you are trying to connect to the Finesse Notification Service with a UCCE Finesse deloyment. As far as I remember, the XMPP connection to the Finesse notification service needs to use the agentId and not the username. So even though the library allows a connection to be made with username, it isn't going to be very helpful in the CCE deployment.
Also, is there a reason why you are trying to use CAXL vs Strophe? Strophe is the recommended library.
Thanx,
Denise
The reason is that we have been using CAXL for a while now in our products.
