CCX 11.5 (Premium) - Maximum Operational Capacity
adnanhassan1
Hi Guys,
We are curremtly using CCX 11.5 (Premium), Could someone help me find a document where I can find the following information:
1- Max number of IVR supports
2- Max CTI ports
3- Max number of Queues can handle
4- Max number of concurrent calls can handle
5- Max agents is 400, but how many agents can login and answer calls same time?
Chris Deren
This should help:
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cust_contact/contact_center/crs/express_11_5/design/guide/uccx_b_soldg-for-unified-ccx/uccx_b_soldg-for-unified-ccx_chapter_01000.html
as to concurrent agents, 400 would mean concurrently signed in agents, you can configure more.  Keep in mind that in order to support 400 agents you require the 400 agent OVA to be deployed.
Chris Deren
This should help:
